    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.4k Views 18 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @yad2000 said:
      Line number 569 is:
      face = entities.add_face circle
      try:
      face = entities.add_face( circle.edges )
      I'm not here much anymore.
      • yad2000Y Offline
        yad2000
        That's right, because you're not going to work. This plugin is targeted to the appropriate users. You have added a new document and a new tube without any parameters, of course anything you do will not work. The parameters necessary to specify everything: nominal diameter, outside diameter, wall thickness, the name of the pipeline, etc. All that is required.
        So that promote your cause, or assist in the development or discourage new users
        CoolPipe Plugin
        • yad2000Y Offline
          yad2000
          Please bring a list of documents for which you want to add elements. Now used only 2 Russian document on the piping. If you write a number of documents that you use and you can download them somewhere, I'll add them to the database to avoid similar mistakes.
          CoolPipe Plugin
            tony bombata
            @jorge2011 said:
            I receive the following error code after installing.
            Thanks you in advance for your help.
            Ken
            You must copy the file "iconv.so" in the folder:
            windows/system32
            i use x64 windows and i had the same problem
            copied iconv.so and iconv.dll to win2, wow64, sketchup plugins and coolpipe folders
            don't know which worked out but it's working
              Dan Rathbun
              Well which one of those paths are in the $LOAD_PATH array ??
              • guanjinG Offline
                guanjin
                I can not open the page, to download, why not posted on the website
                • yad2000Y Offline
                  yad2000
                  Coolpipe.ru site - located in the ucoz.com - if none of the sites of ucoz you can not read - then the problem is with your provider.
                  CoolPipe Plugin
                  • guanjinG Offline
                    guanjin
                    @yad2000 said:
                    @irwanwr said:
                    if the plugin will be available in English version and shared here too.
                    if it is true.
                    this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
                    Finally downloaded, loaded error
                    • yad2000Y Offline
                      yad2000
                      @guanjin said:
                      @yad2000 said:
                      if it is true.
                      [attachment=0:15v5ur39]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:15v5ur39]
                      in the file that you changed - Error!
                      you must:
                      "沿线 管道 目录 列表,
                      replaced by
                      "沿线 管道 目录 列表",
                      should work
                      CoolPipe Plugin
                      • guanjinG Offline
                        guanjin
                        Successfully translated into Chinese, but has not been used successfully, the of plumbing tools?
                        • yad2000Y Offline
                          yad2000
                          Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford
                          CoolPipe Plugin
                          • guanjinG Offline
                            guanjin
                            I do not know that you mean ,the file is a common indoor plumbing components
                            • yad2000Y Offline
                              yad2000
                              I also do not understand what you want)))
                              CoolPipe Plugin
                              • yad2000Y Offline
                                yad2000
                                I will say this: I have now developed a new version of the plugin, which will not appear on [iconv] and [web dialogues]. The most interesting thing to come, as the plugin will look - still a secret. When will the release of do not know. Work to be very much as I want to do everything in Ruby without any HTML and JavaScript
                                CoolPipe Plugin
                                • yad2000Y Offline
                                  yad2000
                                  who knows how to use the database MongoDB in Ruby for SketchUP ❓
                                  here...
                                  CoolPipe Plugin
                                  • yad2000Y Offline
                                    yad2000
                                    Time is now developing a new interface for plug-in.
                                    Here is a screenshot
                                    I want to abandon HTML, JavaScript, CSV. I am looking for ways to solve problems with the database.
                                    Who share the standards DIN / EN / ISO / API / ASTM / ASME?
                                    CoolPipe Plugin
                                    • yad2000Y Offline
                                      yad2000
                                      Who shares the standards DIN / EN / ISO / API / ASTM / ASME?
                                      For further development of the plugin. Interest standards for all items, not just on the tube. At least to start with 2 pcs. You can share the standard is not complete, but only the image and style options.
                                      Google Translator gives terrible translations)))
                                      In Russia, the translation is: "Your - my not understand"))))
                                      CoolPipe Plugin
                                      • kenK Offline
                                        ken
                                        Hello
                                        I have tried and tried to get this program to work. I keep getting the attached error. I have the file, iconv.so in the correct directory as shown.
                                        So what is wrong, and can it be fixed? I deal with pipes diagrams and would like for this to work.
                                        So thanks in advance for your help.
                                        Ken
                                          driven
                                          Hello
                                          Ken
                                          Start.rb is not finding iconv.so is what your message says, and it needs it so it reports an error....
                                          I'm on mac, but it looks like you need to put the missing file into your plugins folder >>> iconv.so
                                          • FrederikF Offline
                                            Frederik
                                            Looks like a very interesting plugin... 👍
                                            Unfortunately I seem to share the same issue as Ken...
                                            I've never had any issue installing a plugin - before now... 😕
                                            I even tried to copy the iconv.so to the plugins folder, but to no avail... 😐
                                            Cheers
                                            Kim Frederik
                                            • 3 / 4
