    Ideas for modeling chair?
    3 Posts 2 Posters 1.5k Views 2 Watching
      miikka1978
      I would like to model this Artek chair http://www.artek.fi/products/armchairs/9. It is no problem to model the wooden frame, but the fabric/texture part of the chair is problematic. What could be efficient way to model the fabric? I would like to render the chair so flat surface with some holes in it wouldn't be enough.
      Please let me know how you would do it. This could be a good learning point for me!
      http://i.imgur.com/frrU5.jpg
      http://i.imgur.com/B4OQq.jpg
      • ely862meE Offline
        ely862me
        There is no trick, you just have to think of modeling it as if you will actually build it.
        Create the stripes then intersect them separately and move up and down the portions that cross over and under each other.
        My stripes looks a bit edgy but you can add some more segments to make them more sinusoidal .
        You can use joint push/pull if you want to give them thickness .
        3 by EliseiDesign.skp
        Hope this helps!
        Elisei (sketchupper)
        Come and See EliseiDesign
          miikka1978
          Thanks a lot, that intersect with model didn't come to mind at all. Also, I was thinking about model directly with thickness but it is much easier to create the stripes flat first and then use push push/pull.
