    Graphics Cards please ?
    11 Posts 7 Posters 898 Views 7 Watching
    • H Offline
      haynesc
      Hi what would be the value for money - most powerful graphics card for use with Adobe CS5 & Sketchup for the following machine:
      Dell Vostro i5 3GHZ 8GB RAM
      Suggestions please
      • N Offline
        numerobis
        http://www.cgarchitect.com/news/newsfeed.asp?nid=4960
        The fastest sketchup card seems to be still the old Geforce GTX285.
        But i would suggest a GTX560 TI 2GB. I have one too. Works great so far and power consumption is ok compared to the high end cards 😉
        • mitcorbM Offline
          mitcorb
          Hi, haynesc:
          For more information, see what AdamB says here, with some links to look at:
          http://forums.sketchucation.com/viewtopic.php?f=15&t=40976
          EDIT: @numerobis: I see we posted almost simultaneously. That cgarchitect link is very interesting, and probably more to the point.
          • fuzzionF Offline
            fuzzion
            Limitations stem more from SU than your video card. But with that said, do not
            go with the problematic SLI and opt for 460gtx or above.
            "Only the dead have seen the end of war" - Plato
            • H Offline
              haynesc
              uhm ok i should have said that im not a technical expert and have no idea about graphics cards, im just after a solid recommendation on which to buy
              thanks
              • mitcorbM Offline
                mitcorb
                Hi, haynesc:
                I am not too much different from you in terms of knowledge in this area. I think it would be a good idea to delve into some of this information, so that when the solid recommendation comes along, you can at least make an informed choice. But it has been stated that Sketchup is not the crucial factor in your choice. It would be any of the image processing programs you use, such as Photoshop, or the render programs you use.
                  dtrarch
                  My choice for a new system with i7 second gen and an Asus P8Z8-F/GEN3 mobo.
                  GeForce GTXZ 550 Ti 2GB GDDR5.
                  About $109-119 US for 1GB and $176 for 2GB
                  http://uk.geforce.com/hardware/desktop-gpus/geforce-gtx-550ti/specifications.
                  Sketchup ready and affordable.
                  I'm not a pro on video hi end stuff but this looks like pretty good match for SU.
                  4.1 open GL and good clock speed etc.
                  Check it out and comment please.
                  dtr
                  • H Offline
                    haynesc
                    So GeForce or Nvivda ? my budget is around £50 per machine
                      GeForce is a product by nVidia...
                      • sketch3d.deS Offline
                        sketch3d.de
                        that's not much... the nVidia Geforce GT 440 is probably the 'best bang for the buck' you can get for this small amount of money.
                        Add roughly £30 and you will get something more capable as e.g. the GTS450.
                        And keep an eye on the power consumption, the GTS450 consumes ~100w if forced, in peaks up to ~135w. Which requires a power supply unit of min. 300 watts.
                        hth,
                        Norbert
                        • H Offline
                          haynesc
                          hth,
                          Norbert
                          Thanks very much
