    Bake shadows in Sketchup and export in COLLADA...???
    5 Posts 4 Posters 2.0k Views 4 Watching
      Montnegre
      Hello!
      I wish export my model in COLLADA .dae format, with shadows baked in the texture, as a lightmap. Could be it possible?
      Do you know other way to do it?
      Thank you!!
      • numbthumbN Offline
        numbthumb
        I am not sure, but I believe that this was the idea behind LightUp: http://www.light-up.co.uk/ πŸ˜•
        Comfortably numb...
        • TIGT Online
          A DAE file contains geometry.
          Shadows are created in the SKP using OpenGL so they aren't geometry.
          A DAE file also has no camera or shadow settings in it so you can't replicate those either.
          I have a draft ShadowProjector tool that projects the shadows of selected objects onto the rest of the model as edge-outlines of the shadows...
          Watch out for its first release...
            Jim
            You might try this plugin:
            http://forums.sketchucation.com/viewtopic.php?t=21077
            It generates and applies AO shaded image-based materials right in SketchUp, which should export using the collada exporter.
            • TIGT Online
              You might be interested in this new tool http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
