    Sparkling lights
    renderpluginsextensions
    7 Posts 5 Posters 1.6k Views 5 Watching
    • E Offline
      edison
      Hello,
      I tried to search forum about this, but didn't find. So, very simple question. How to make sparkling lights in v-ray, like in example I attached? Thank you!!!
        rspierenburg
        My best thought would be to use small emmisive materials for the lights and then add sparkle in post-production.
        • V Offline
          valerostudio
          Yep. This is done in Photoshop. There are a number of tutorials onlione how to accomplish this.
          • V Offline
            valerostudio
            If you like, you can use this PNG file, just copy it into PS, lay it on top of your render, change the blending mode to screen, and play with the brightness and opacity of this layer to adjust its effect.
            • dkendigD Offline
              dkendig
              There is a V-Ray Lens Effect that will be added in the next release that will do this as well.
              Devin Kendig
              Developer
              • V Offline
                valerostudio
                This seems useful also http://browse.deviantart.com/?qh=&section=&q=lens+flares#/d2momj0
                • Bob JamesB Offline
                  Bob James
                  Great source: thank you
