    Fill slope
    9 Posts 5 Posters 510 Views 5 Watching
    • 7 Offline
      7416bram
      http://img210.imageshack.us/img210/4599/schermafbeelding2011112d.png
      See the image above. I want to fill up the slope, at the bottom (the single lines). How is this possible? It is a parking garage.
      Thank you very much.
        bjornkn
        It's a lot easier with a plugin.
        Check out Shape Bender (there's a video doing exactly what you want),
        Curviloft and TGS's ExtrudeByxx tools.
        They should all do the job, and so would Amorph from tgi3D.
        • 7 Offline
          7416bram
          How to install this plugin?
            Which one?
            • 7 Offline
              7416bram
              The ShapeBender...
              • boofredlayB Offline
                boofredlay
                Certainly you could do it with a plugin but the easiest way to do this is to stitch the endpoints together. Just use your draw tool and connect the points, triangulating the mesh until it has been filled in. I think it is a good idea to learn the basics before getting confused with plugins.
                  boofredlay
                  Like I said above, draw from point to point triangulating the points. Fill in the ramp then smooth. Copy the ramp in the blue axis the desired thickness then stitch the sides together. It took me 3x as long to write this and format the images than it did to build the ramp. Sometimes simple is better IMO.
                  Hope this help Bram. Oh, and welcome to SketchUcation. πŸ˜„
                  • 7 Offline
                    7416bram
                    Thank you for your reply. The last step (removing the lines) is not possible, it wil be emptied again... How did you do that? πŸ˜„
                      Erase+Ctrl >>> smooth edges
                      as used here OR also
                      Erase+Shift >>> hide edges
