    How to make smooth texture transitions
    renderpluginsextensions
    4 Posts 2 Posters 856 Views 2 Watching
      llonghi
      Hello everyone,
      I made an image for a client, and there´s a issue I want to fix.
      In the image below, you can see the asphat meeting the sidewalk is not smooth. What would be the best way to do it?
      Also, I would appreciate if someone coul point other problems or what could I do to make the image better.
      OBS. The paved floor is small, I know! 😄 this is a preview image.
      Thanks!
      • dukejazzD Offline
        dukejazz
        Your object looks very nice.
        Things I think would help:
        1)The black area is your asphalt right? There is a plugein call workplain that you can lay a texture on, so that you object just dosn't flot in the air like style gound give you. Edit the asphalt jpg texture with contrast and brightness or take a real photo of a parking lot or (hint photo texture on google earth) command bar_window_photo textures.
        1. Raise you object with a flat rectangle may help (push pull 1/2").
        When you get it looking way you like in sketchup then render it with other program for the illustrations you want.
        I use sketchup like a note pad because it fast and visible.
        Have a good holidays
          llonghi
          Thanks Duke,
          The google maps texture seems a great idea!
          I´ll also try the plugin.
          But unfortunately, here in Brazil is not holiday! 😕
          • dukejazzD Offline
            dukejazz
            Holidays range usually one and a haft months around the shortest day of the year here.
            Have a good day then.
