    KungFu is not Strong!!
    3 Posts 2 Posters 260 Views 2 Watching
    • W Offline
      WillPowers
      Can anyone help me with this? I am trying to close all faces where the two roof forms meet, but my KungFu is not Strong!!
      Thanks!!
      Roof Planes Intersection.skp
        You have bits of hidden lines, faces not quite parallel etc...
        I suggest you make the main gabled-roof again cleanly. and then make the 'dormer' as a simple over long gabled-roof at right-angles. Intersect all of them together. Erase what you don't want... and cut the angle to the front piece of the dormer with a temp face...
        Trying to work with everything you've made is very awkward as you have so many hidden glitches etc...Capture.PNG
        • W Offline
          WillPowers
          TIG,
          Thanks! I will do as you suggest! Makes perfect sense and should work intersecting two roofs first then cleaning up....
