    Trying to 'engrave' one group onto another
    3 Posts 3 Posters 289 Views 3 Watching
    • H Offline
      helios
      I am trying to model a ring with an engraved crest. I created the ring blank as one group and the crest as another. The crest is basically a flat design that I was hoping to drape over the ring and then push in certain details. However, if I try to run drape, Sketchup crashes.
      Any idea what I'm doing wrong? Model file is attached.
      's Ring 1d3.skp
        Perhaps you could try Sketchup's Sandbox > Drape OR my 'SuperDrape'...
        BUT
        Because your 'logo' is very poorly formed, with many unnecessary edges etc, it will take a loooooong time !
        Even if you scale it up temporarily to avoid tiny facets >>> Bugsplats...
        Why not remake it, somewhat simpler ?
        The super-fine detail will never be seen anyway... πŸ˜’
          bestmate
          HI, i used the drape tool in a small section and that stopped the crashing ,but it did not transfer very well leaving spaces. So then i pulled the design through the ring and intersected with model and deleted unwanted geometry. .I then used fredo's pull push tool and it did not seem to bad . i did not pull it the whole through but have a look at the file i sent back .
          Regards Phil
