    Dimensioning Angles
    7 Posts 3 Posters 932 Views 3 Watching
      Btipf
      Hi. I can't seem to get the dim_angle.rb plugin to work (in SketchUp 8). The new tool I'm expecting to see doesn't show up. Can anyone recommend an alternative plugin? Thanks!
        Have you installed it properly and looked for it in the right place ?
        The DimAngleTool appears under this menu
        UI.menu(" Tools").add_item(" Angular dimension")
        Please read its instructions...
        Also remember that the order you pick the points affects the drawn result!
        πŸ˜’
          Btipf
          Thanks, TIG. I was able to find and use the Dim Angle tool in Sketchup 6, but previous efforts to find it in SketchUp 8 didn't work out for me. I'll try it again tonight.
          After reading your much-appreciated reply, I went looking around for instructions for this tool. I couldn't find any at the Ruby Library Depot. I then opened the .rb file in Notepad and read, "Click 3 points counterclockwise." Unless I'm advised otherwise, I'll assume this is the method typically used to provide instructions to plugin users.
          Thanks again!
            πŸ˜’
            You must have the ' dim_angle.rb' file in your SUp 8 Plugins folder ...
            πŸ˜•
              Btipf
              TIG, I verified that I do have the dim_angle.rb file in my C:/Program Files/Google/Google SketchUp8/Plugins folder of my Windows 7 PC, yet I can't see the angle dimensioning tool in my Tools menu like I can for my Windows XP PC at work running SketchUp 6.
              Just for the heck of it I then downloaded and installed the French version of the plugin on my SU8 PC, but I still couldn't see the additional tool on the Tools menu. I wonder if other Windows 7, SketchUp 8 users are able to select this plugin tool?
              Thanks for your help!
                OK... Windows-Vista and Windows-7 have a stupidly hyperactive [but uncommunicative] 'security checking' system... that might be it πŸ˜•
                If you put a file into a folder on which you have insufficient access-rights, instead of Windows telling you that, it looks like the file went into the folder, BUT in actuality it's been put in a 'Compatibility Files' folder [I think Win7 has another similar name ?] so it doesn't auto-load from there, as it would had it gone properly into Plugins! Windows protects you from yourself, but doesn't let on!
                The clue is that a 'Compatibility Files' button [or similar] is added to the top-bars of any folder's windows that have this issue - clicking on that reveals what's not really been loaded.
                To fix/avoid...
                Ensure that you are a full Admin in your User settings.
                Change the Permissions on the Plugins folder [and the Components, Materials and Styles folders too as you might want to write to those from time to time] - to do this right-click on the folder's icon > Properties > Security > Edit, change permissions to 'Full control' [All?] for you, AND for others who need it.
                Now move the scripts etc across or reinstall them from scratch...
                πŸ˜’
                  jpalm32
                  To fix/avoid...
                  πŸ˜’
                  Thank you so much!! I couldn't get rid of Engineerintoolbox.rb and I thought I was going crazy!
                  It still don't make sence though! Download some rb, goes in standard folder, download another goes in hidden folder, Same permissios, same user.
