    Best free Plug-in's
    30 Posts 10 Posters 4.2k Views 10 Watching
    • J
      JMdesigns
      😎 ...Hello everyone. I am new to this forum, and new to SketchUp. so far I love it.
      It is very easy for me to pick up, i am a graphic designer in the sign industry. I am very use to photoshop, and
      love all the plug-ins for it. I was happy to see that SU has plug-ins 😍
      What are the best FREE plug-ins for SU. I am trying this program out for the company i work for, and they dont want to spend alot
      on it. so free would be great, thanks
      • boofredlayB
        boofredlay
        Most of the ones listed here are free. It should get you started.
        http://forums.sketchucation.com/viewtopic.php?f=323&t=16909
        • Chris FullmerC
          The large majority of plugins are free at this point in time. Check out the link to "Plugins Index" at the top of the page (in the red box), or here is the direct link:
          http://forums.sketchucation.com/viewtopic.php?p=250026
          Most of them listed there are free with very few exceptions. And those that are not free are not that expensive for the most part.
          Then check out the Ruby Depot curated by Didier Bur here:
          http://rhin.crai.archi.fr/rld/plugins_sections.php
          And smustard has a large amount of free plugins and some pay ones. Again, the pay ones are not very expensive, generally under $20.
          http://www.smustard.com
          As for which are the best - well that depends on what you need a plugin for! As a general guide, I would say go through and read what the plugins do. Download those that look useful to what you think you need. Then as you learn more about SketchUp, you will find things you need help with. Ask here how to do it and generally someone will help. And sometimes someone will recommend a perfect plugin to help. Often though, lost things can be done w/o plugins.
          Anyhow, good luck. hope thats a good starting point. And don't let my comments keep anyone else from chiming in if they have something to add.
          Chris
          All my Plugins I've written
            Extrude Line http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=1523 by Didier Bur
            Joint Push Pull http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708 By Fredo6
            Tools on surface http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212 By Fredo6
            Bezier http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563&st=0&sk=t&sd=a&hilit=bezier By Fredo6
            Pack des outilsd'extrusion by TIG avec notamment extrusion par 2 Rails! 😎
            FredoScaleFree Scale Bend by Fredo6
            Shape Bender By Chris Fullmer
            Component StringerBy Chris Fullmer
            Cleanup by Thomthom
            Mirror http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11532&p=80373 by Frank Wiesner
            Grow (Multiple Copy Move rot size en même temps! ) http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Grow.rb by Tig
            Inverse Selection http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/InvertSelection.rb by Tig
            Extrude along a path http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/ExtrudeAlongPath.rb by Tig
            Double Line (Walls) http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12853 Didier Bur
            Weld curves (or lines) http://www.crai.archi.fr/RubyLibraryDepot/Ruby/fr_weld.rb by Rick Wilson
            Projections by Didier Bur http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=960&st=0&sk=t&sd=a&hilit=projection+didier+bur
            FFD Box of deformation http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6029 by CPhillips
            Clean coplanar surface (inside this plug Skin) http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6912 by architectboy
            Follow me and rotate http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13014&st=0&sk=t&
            sd=a&hilit=follow+rotate by wikii
            Follow me and keep
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16465&st=0&sk=t&sd=a&hilit=follow+rotate#p129504 by Wikii
            Taper, curve maker http://www.drawmetal.com/home by Draw Metal
            Animation http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10946&st=0&sk=t&sd=a by Morisdov
            et tout ceux de Chris Fullmer http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17358&p=139011#p138625
            (ils sont en blocs petits mais très utiles)
            Subdive and Smoth (basic free) http://www.smustard.com/script/Subdivide by Ricks Wilson
            not free http://www.smustard.com/script/SubdivideAndSmooth by Whaat
            Funny & sérieux
            SketchyPhysics http://www.sketchucation.com/forums/scf/viewtopic.php?f=61&t=17324&st=0&sk=t&sd=a&hilit=SketchyPhysics#p138266 by CPhillips
            Protrude by Jim Folz http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13095&st=0&sk=t&sd=a&hilit=protrude#p95818
            Zorro2 http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16038&st=0&sk=t&sd=a&hilit=zorro2#p124862 by Whaat
            Soap Skin Bubble & Tensile structures (free) http://www.tensile-structures.de/help.html by Josef Leibinger (free suivant beta)
            • J
              JMdesigns
              Thanks everyone 😄
              • X
                xrok1
                Wasn't there a must have plugin thread? I can't find it but...
                “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  While the majority are free it is worth mentioning that a lot of authors accept donations.
                  If you save time and earn money from using their plugins then rewarding them for their hard work is good karma for the soul.
                  • Mike LuceyM
                    Mike Lucey
                    JD,
                    I think your attitude in this regard should be discouraged. I presume you would not look very favorably on me if I arrived at your Sign Design Shop and expected free signs even if you had a few 'free' offers in place. I imagine you would like to see some genuine support business taking place also.
                    I agree with Rich. Most of the Plugins available here are 'free to use', however in order for many of the Ruby Authors to continue development of their various plugins they should be helped / encouraged with contributions, however small.
                    Think of it as dining at a good restaurant and tipping the staff for an excellent service / meal, not obligatory but prudent, as it only improves service for the next time you dine at the restaurant.
                    I imagine very few Ruby Authors expect to make fortunes but they do like to receive small contributions as it shows that their work is appreciated. This in turn encourages them to continue and improve their Plugins.
                    From my knowledge, on talking to many Ruby Authors, there are not a lot of support donations made, most 'grab and run'! However, the few genuine users that do make supporting contributions are much appreciated and for the most part, its these genuine supporting users that ensure useful and innovative Rubies will continue to flow.
                    So, all that remains, is for me on behalf of the Ruby Authors, to thank the genuine and generous supporting contributors 👍
                    Mike
                    • boofredlayB
                      boofredlay
                      Check my post above Rocky. 😉
                      • J
                        JMdesigns
                        Mike,
                        you miss understood me. First off, thank you to all. especially the Ruby authors for your work. I was stating that it would be great to have free plugins at this point, because the company i work for basically thinks this program is useless, and too difficult to learn. I took on the responsibility myself, of learning the
                        program on my own time, and trying to see if we can use it in this industry. They basically are giving me no support, so i am trying to learn it and put together some nice "skills" to show them 😍 . I already used this program in redesigning my home to show my wife. thanks again. i will start to download some of the plugins tonight......thank you all for your input and support
                        • Jean LemireJ
                          Jean Lemire
                          Hi JD, hi folks.
                          I have an answer that you can give to those people that are telling that SketchUp (SU)is useless and too difficult to use.
                          Tell them that SU is not a CAD software so, you cannot compare it to Software like AutoCAD, Catia, Inventor, Revit, etc.
                          Tell then that SU has one of the most, if not the best help system, especially if you include in that the myriad of video tutorial on the SU's site, YouTube and many other sites.
                          Tell them that there are quite a few user forums, SketchUcation included, that are probably considered as top notch for this kind of software.
                          I base these assumptions on the fact that I have been using and worked with people using all the above mentionned softwares and many others and, to my knowledge and experience of 33+ years in engineering and 40+ years of computer use, SU is the only drawing software that allows me to produce a sketch without interposing itself between my ideas and a completed model.
                          Just ideas.
                          • X
                            xrok1
                            thats the one. 😳 thanks for the reminder.
                              Yes! ☀
                              And in the Nurbs' world the other prog is Moment of Inspiration (Moi) 🤓 😄
                              • J
                                JMdesigns
                                thank you....these look awesome. cant wait to try'em
                                • J
                                  JMdesigns
                                  Thank you all 😛 ....I downloaded some last night, and they are awesome. i am really taking to this program. I generally work in full scale,
                                  so this program is perfect. I am still trying to see how we can use it for signage (monuments, and cabinets).
                                  One of the biggest problems i can see right now, is the inability to open EPS files like customers logo's, special fonts. Is there any plugins for this?
                                  • TIGT
                                    Appealing to your parsimoniousness... try a Google search http://www.epsconverter.com/ http://www.epsconvert.com/search.aspx http://vectormagic.com/home for free or inexpensive online/app eps converters - there are loads of them - even ones you can lots pay for...
                                    Also free the free image editor 'Gimp' can do import eps and export to png/jpg etc - http://www.squidoo.com/epsGIMP http://opencomputer.net/2008/04/22/tip-open-eps-files-with-gimp/ - and much more [but surely you have Photoshop or Illustrator?]
                                    If you want vector info out of the eps then you could try to make a dxf [perhaps with the intermediate step of an online pdf conversion] or even Inkscape svg?... or other vector file type you can import into a SKP...
                                    • J
                                      JMdesigns
                                      These Plugins are amazing ....I wish i had more time to play with this program, and get more familiar with its features.
                                      I recieved a layout request today that i think will be perfect for SU.
                                      The customer wants to see their logo on a basic 6' x 8' monument with a water feature base.
                                      My only problem is getting there logo, which is an EPS file into SU. Any advise? thanks
                                      • TIGT
                                        Convert it to a PNG with transparency.
                                        Import the Image and use my ImageTrimmer to 'cut it out'... OR just explode to a face with material, draw around it and tidy up etc... BUT without seeing the logo it's hard to comment - though I'd expect it's not too complex ??
                                        • J
                                          JMdesigns
                                          Thanks TIG ! Where can I get your ImageTrimmer? i got some time know and want to play around with the program
                                          • massimoM
                                            massimo Moderator
                                            Press the big red button called "Plugins index" on top of the page then go to TIG-->image trimmer.
                                            • 1 / 2
