    REQ: SOME SORT OF SKIN/WELD PLUGIN.
    11 Posts 6 Posters 1.5k Views 6 Watching
      jonorman
      Hi.
      Im looking for a way to fill in deleted vertices from a terrain model (see illustration/pictures) Some vertices have been deleted in the terrain model and Im thinking something like soapskinbubble to fill it up again.
      This works somewhat, but leaves a bunch of error messages when trying to use Artisan 2 to smooth or subdivide. Hope you get the idea of what I`m looking for. β˜€
      Deleted vertices needs to be filled in
      Using soapskinbubble plugin, exploding the group, and using TT cleanup.  looks ok.
      Error msg trying to use Artisan for smoothing of subdivide.
        Triangle Mesh Completer
        MeshLAb for convert files! πŸ˜‰
        (Meshlab knows also fill the gaps πŸ˜‰
        by Aiem
        http://www.ae3d.ru/img/m009.jpg
        http://www.ae3d.ru/img/m010.jpg
        • TIGT Online
            jonorman
            Thank you for replies. will test and see... πŸ˜„
            • voljankoV Offline
              voljanko
              You can do it also with the SuSolid plugin that has a "close holes" tool.
              On the picture you can see how it closes a very complex hole.
              SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
                jonorman
                the issue is not closing a gap, that can be done using SU's native tools. the thing to have is a hybrid between TIG's "extrude" plugin and sopeskin bubble, if that makes any sense. πŸ˜‰
                • X Offline
                  xrok1
                  did u try curviloft?
                  β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  • G Offline
                    gulcanocali
                    Hi jonorman,
                    You can also use Tgi3D SU Amorph's "Create Mesh" command. Simply select the border of the hole, very easy with Tgi3D's Select Tool; with just one [Ctrl+left mouse] click the entire border is selected. Then run "create mesh" command. Voila!
                    Gulcan Ocali
                    Product Manager
                    http://www.Tgi3D.com
                      jonorman
                      My 30 days trial are used, my wallet says no, not yet.. That sure is a nice program though πŸ˜„
                      • G Offline
                        gulcanocali
                        Incidently, we have been thinking of renewing previously expired 30 Day Trials for another 30-days. We have introduced many interesting features since the initial release of Tgi3D SU Amorph and PhotoScan, therefore we would like the folks, who showed an interest in our products earlier, to have another chance to take a look at Tgi3D SU plugins with the new and improved features. It should not be too long before we announce this.
                        Gulcan Ocali
                        Product Manager
                          jonorman
                          Dang, missed your comment there Xork1... How could i forget curveloft.. Now tested and result is acceptable. Thank you for the tips. β˜€
