    SU8 Pro - blending intersecting surface
    3 Posts 2 Posters 372 Views 2 Watching
    • O Offline
      oldswinger
      Hi All
      I have just subscribed to SketchUcation in the hope I will be able to expand my limited skills of using Sketchup with civil construction projects.
      I have been using SU8 Pro & it's predecesser for a couple of years & am familiar with the basics but I find SU rather limited when it comes to blending intersecting surfaces - a simple example a round neck of a bottle joining a rectangular body'
      I have viewed an ideal solution on a programme called Bonsai 3d but wonder if anyone knows of any SU compatible ruby scripts which could do a similar task.
      Any suggestions would be appreciated.
      Old Swinger
        Curviloft would make light work of it. Hit the red Plugins Index button and you'll find it under Fredo's name. I recommend watching his videos and reading all of the first post.
        Welcome to SCF πŸ‘
        • O Offline
          oldswinger
          Hi Rich
          Thank you very much for your advice to try Curiloft - Fredo is a genius.
          I have tried to find a text user manual for Curviloft without avail as I am learning to use the plugin from various video samle tutorials which are two fast for me. Do you know if a pdf manual exists even if it for earlier versions of the plugin.
          Also is it possuble to enlarge the tool bar - I have my tool bar setting on Large Toolbar but I could do with it being larger.
          Many thanks for your prompt resonse to my initial topic & I am sure I will get a great deal of help & information from SketchuCation.
          Regards
          Old Swinger
