    Tree shadows
    renderpluginsextensions
    8 Posts 4 Posters 1.1k Views 4 Watching
      Ben Ritter
      I just installed a demo of Vray for Sketchup. Since then I have 2 issues that may be because of the Vray install,
      1. The tabs on my IE browser are all turned blue
      2. I can't seem to get the 2.5d trees to cast shadows when rendered, whether I use Vray, SU Podium or Maxwell. By the way, I'm new to Vray and Maxwell, so there may be settings I'm unfamiliar with.
      Any thoughts?
      • majidM Offline
        majid
        try adjust your material transparency, as shown in image
          Ben Ritter
          Majid,
          Thank you for your reply. However, I don't understand what file you're implying I find and what setting I should try?
          Again, I appreciate your help.
          Ben
            Ben Ritter
            It's not just in Vray, but also in SU Podium where the shadows are not rendered.
            • V Offline
              valerostudio
              This sounds like it is related to the component itself if the shadows do not render in any of these programs. Could you attached the file so we can look at it?
                Ben Ritter
                I noticed that even a simple box, drawn in SU, does not render with shadows, so perhaps something with SU has changed.
                  Ben Ritter
                  Thanks everyone. I have the problem solved.
                  • arail1A Offline
                    arail1
                    It's a good idea to explain how you solved your problem so someone who is following this thread or finding it by Searching will know what the solution is.
