    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 57.1k Views 19 Watching
    • Z Offline
      ZFRPS
      First thanks your arduous jobs for everybody !
      NOW,01.jpgtest01.skp
      sketchup is bim
      • Z Offline
        ZFRPS
        So,about length of group,maybe i think first need a plugin:SOLIDGROUP TO LINEGROUP,then count length of linegroup,and when sketchup to CAD ,PIPE-linegroup very nice than solidgroup!
        Can you help me for plugin:SOLIDGROUP TO LINEGROUP?
        Thanks again !02.jpgtest02.skp
        sketchup is bim
          tak2hata
          Thanks again ![attachment=1:xrfumwyc]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:xrfumwyc][attachment=0:xrfumwyc]<!-- ia0 -->test02.skp<!-- ia0 -->[/attachment:xrfumwyc]
          Hi, zfrps.
          I think it is very difficult.
          I will consider it future.
          Thanks.
          by TAK2HATA
          • O Offline
            OSN58
            What this number?
            Thanks.
              tak2hata
              @osn58 said:
              What this number?
              Thanks.
              Hi,OSN58.
              "SUB TOTAL"is sub total of volumes in that group,when The Solids exists in the Group.
              The group name is displayed in "PARENT NAME"
              Thanks.
              by TAK2HATA
              • O Offline
                OSN58
                Sub total of COST in that group,when The Solids exists in the Group does not work?
                Thanks.
                  tak2hata
                  Thanks.
                  Hi,I update solid quantify2 to v2.0b.
                  OSN58....
                  "Cost" in subtotal is incorrect.
                  It fixed now.
                  Thans.
                  by TAK2HATA
                  • O Offline
                    OSN58
                    Great plugin.
                    Thanks.
                    • O Offline
                      OSN58
                      How to make localization of a plug-in (on Russian)?
                        lyvirak
                        ありがとうごさいます。
                        • H Offline
                          HenkW
                          This plug-in is great, but I found an error that renders the results unusable. Some of the material areas are doubled while most are correct in the generated reports. Secondly, in the the web dialogue there is a minor error that the volume is shown as "m" only in stead of "m³", while the distances are shown as "m³" in stead of just "m". If the first error regarding the incorrect doubling of areas could be fixed this plug-in would be perfect. Attached are a screen shot of the report as well as the SU model used to generate the report.
                          Sample report and SU model
                          • H Offline
                            HenkW
                            Screenshot of error report with wrong areas indicated.
                              tak2hata
                              Hi,Henk.
                              Thanks for your helps.
                              I will fix the problem in few days and update here.
                              Thanks.
                              by TAK2HATA
                                tak2hata
                                Hi,All and Henk.
                                I update this.
                                There are two Bugfix.
                                Surface area calculated double,when that face do not have back-material.
                                And mistaked about units when report rendered in webdialog.
                                This problem fixed.
                                Thanks.
                                by TAK2HATA
                                • H Offline
                                  HenkW
                                  TAK2HATA, you have done an awesome job with this plug-in! Thanks for the fix, we are pushing its abilities to the limit. It requires a lot of discipline to keep everything clean and tagged properly to get the required results. For those who are using this as well, when models get really big and you can't seem to find why there are still errors... Make sure that the axes of all groups in a multi-level component are identically aligned. Use in conjunction with the plug-in “Solid Inspector” for quick results.
                                    camilozunga
                                    Hello and thanks for your plugin, I just find it a few days ago and it's just perfect for what I need... Unfortanetly in my MAC is not working well, don't let me export xml, don't let me apply solid materials, JUST LET ME VIEW IN WEBDIALOG and the most of the measures of elements oriented in Y axis appears in 0.00, did you or anyone mac users who are using this plugin can help?
                                    thanks.
                                    • Q Offline
                                      QS3D
                                      Excellent Plug-in!! How to I change the quantities to SF and CY (ft^2 & yards^3)??
                                        tak2hata
                                        Hi,camilozunga.
                                        I will test the problem on mac.
                                        Please wait. 😉
                                        Hi,QS3D.
                                        I made this plugin be using simply.
                                        So there are only "meter" or "inch".
                                        I will add selecting quantities units.(maybe units in Sketchup).
                                        Please wait. 😉
                                        Thanks.
                                        by TAK2HATA
                                        • Q Offline
                                          QS3D
                                          Looking forward to it. Thanks!
                                            camilozunga
                                            @tak2hata said:
                                            Hi,camilozunga.
                                            Please wait. 😉
                                            Hi,QS3D.
                                            Please wait. 😉
                                            Thanks.
                                            Thanks a lot for your answer, I'll be waiting.😄
                                            • 2 / 4
