    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 63.4k Views 19 Watching
      tak2hata
      @osn58 said:
      Sub total of COST in that group,when The Solids exists in the Group does not work?
      Thanks.
      Hi,I update solid quantify2 to v2.0b.
      OSN58....
      "Cost" in subtotal is incorrect.
      It fixed now.
      Thans.
      by TAK2HATA
      • O Offline
        OSN58
        Great plugin.
        Thanks.
        • O Offline
          OSN58
          How to make localization of a plug-in (on Russian)?
            lyvirak
            ありがとうごさいます。
            • H Offline
              HenkW
              This plug-in is great, but I found an error that renders the results unusable. Some of the material areas are doubled while most are correct in the generated reports. Secondly, in the the web dialogue there is a minor error that the volume is shown as "m" only in stead of "m³", while the distances are shown as "m³" in stead of just "m". If the first error regarding the incorrect doubling of areas could be fixed this plug-in would be perfect. Attached are a screen shot of the report as well as the SU model used to generate the report.
              Sample report and SU model
              • H Offline
                HenkW
                Screenshot of error report with wrong areas indicated.
                  tak2hata
                  Hi,Henk.
                  Thanks for your helps.
                  I will fix the problem in few days and update here.
                  Thanks.
                  by TAK2HATA
                    tak2hata
                    Hi,All and Henk.
                    I update this.
                    There are two Bugfix.
                    Surface area calculated double,when that face do not have back-material.
                    And mistaked about units when report rendered in webdialog.
                    This problem fixed.
                    Thanks.
                    by TAK2HATA
                    • H Offline
                      HenkW
                      TAK2HATA, you have done an awesome job with this plug-in! Thanks for the fix, we are pushing its abilities to the limit. It requires a lot of discipline to keep everything clean and tagged properly to get the required results. For those who are using this as well, when models get really big and you can't seem to find why there are still errors... Make sure that the axes of all groups in a multi-level component are identically aligned. Use in conjunction with the plug-in “Solid Inspector” for quick results.
                        camilozunga
                        Hello and thanks for your plugin, I just find it a few days ago and it's just perfect for what I need... Unfortanetly in my MAC is not working well, don't let me export xml, don't let me apply solid materials, JUST LET ME VIEW IN WEBDIALOG and the most of the measures of elements oriented in Y axis appears in 0.00, did you or anyone mac users who are using this plugin can help?
                        thanks.
                        • Q Offline
                          QS3D
                          Excellent Plug-in!! How to I change the quantities to SF and CY (ft^2 & yards^3)??
                            tak2hata
                            Hi,camilozunga.
                            I will test the problem on mac.
                            Please wait. 😉
                            Hi,QS3D.
                            I made this plugin be using simply.
                            So there are only "meter" or "inch".
                            I will add selecting quantities units.(maybe units in Sketchup).
                            Please wait. 😉
                            Thanks.
                            by TAK2HATA
                            • Q Offline
                              QS3D
                              Looking forward to it. Thanks!
                                camilozunga
                                @tak2hata said:
                                Hi,camilozunga.
                                Please wait. 😉
                                Hi,QS3D.
                                Please wait. 😉
                                Thanks.
                                Thanks a lot for your answer, I'll be waiting.😄
                                  tak2hata
                                  Hi,All.
                                  I update to version2.2.
                                  Add Menu ,"Change Units" for reports.
                                  You can select every units of length , area , volume, cost.
                                  Hi,camilozunga.
                                  I tested solid quantify on mac.
                                  I could not found problem you sayed.
                                  Solid Quantify on Mac.
                                  Green line in this picture is Y-Axis.
                                  The entity was placedalong Y-Axis.
                                  Webdialog is fine.
                                  Please upload here skp file had problem and Screen capture of Webdialog.
                                  Or send it to me by message.
                                  Thanks.
                                  by TAK2HATA
                                  • kenK Offline
                                    ken
                                    tak2hata
                                    Great plugin. I have two questions, the COUNT(pc) what does this field indicate. And the cost, how do you get the cost field to reflect cost.
                                    As for the COUNT(pc) I have made duplicate's of solid, and the COUNT(pc) stays at 1, however it show each duplicate on a separate line.
                                    As for the COST, I have enter cost when I change the unit, as an example, 1.00 for each sq/in and the COST does not change.
                                    So I must be making a mistake just can't seem to track it down.
                                    Thanks you help and plugins.
                                    Ken
                                      tak2hata
                                      tak2hata
                                      Ken
                                      Hi,Ken.
                                      I improves count(pc) of component whitch have volumes.
                                      Now,The components have volumes is counted the figures up.
                                      And I add function to select the components want to be quantified.
                                      Look video in top thread of this.
                                      Thanks.
                                      by TAK2HATA
                                        Souto
                                        thanks.
                                        Great plugin however such as "Camilozunga" i' m not be able using it because won't let me export xml or cvs. I' m been trying with a simple file with a single cube with a basic material.
                                        I' m a Mac user also.
                                        Can you help me on this?
                                        Regards
                                        Souto
                                          mickath
                                          Hi All,
                                          I think this is a very useful plugin, but I do not understand how to use it despite after watching the videos, it will be more meaningful if those video include narration & explanation in sound.
                                          Mickath
                                            tak2hata
                                            Hi,All.
                                            I update this to ver 2.4 in Apr28,2013.
                                            Add Short/Full report for Webdialog.
                                            Bug fix about surface area in scaled component.
                                            Including area of back_face material.
                                            deal with instance name as priority to definition name when the name applied to instance.
                                            Hi,Camilozunga and Souto.
                                            It can work with the model including no solid.
                                            Thanks for the ideas from Goga63.
                                            Thanks! 😄
                                            by TAK2HATA
                                            • 2 / 4
