    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 65.1k Views 19 Watching
    • O Offline
      OSN58
      Sub total of COST in that group,when The Solids exists in the Group does not work?
      Thanks.
        tak2hata
        Thanks.
        Hi,I update solid quantify2 to v2.0b.
        OSN58....
        "Cost" in subtotal is incorrect.
        It fixed now.
        Thans.
        by TAK2HATA
        • O Offline
          OSN58
          Great plugin.
          Thanks.
          • O Offline
            OSN58
            How to make localization of a plug-in (on Russian)?
              lyvirak
              ありがとうごさいます。
              • H Offline
                HenkW
                This plug-in is great, but I found an error that renders the results unusable. Some of the material areas are doubled while most are correct in the generated reports. Secondly, in the the web dialogue there is a minor error that the volume is shown as "m" only in stead of "m³", while the distances are shown as "m³" in stead of just "m". If the first error regarding the incorrect doubling of areas could be fixed this plug-in would be perfect. Attached are a screen shot of the report as well as the SU model used to generate the report.
                Sample report and SU model
                • H Offline
                  HenkW
                  Screenshot of error report with wrong areas indicated.
                    tak2hata
                    Hi,Henk.
                    Thanks for your helps.
                    I will fix the problem in few days and update here.
                    Thanks.
                    by TAK2HATA
                      tak2hata
                      Hi,All and Henk.
                      I update this.
                      There are two Bugfix.
                      Surface area calculated double,when that face do not have back-material.
                      And mistaked about units when report rendered in webdialog.
                      This problem fixed.
                      Thanks.
                      by TAK2HATA
                      • H Offline
                        HenkW
                        TAK2HATA, you have done an awesome job with this plug-in! Thanks for the fix, we are pushing its abilities to the limit. It requires a lot of discipline to keep everything clean and tagged properly to get the required results. For those who are using this as well, when models get really big and you can't seem to find why there are still errors... Make sure that the axes of all groups in a multi-level component are identically aligned. Use in conjunction with the plug-in “Solid Inspector” for quick results.
                          camilozunga
                          Hello and thanks for your plugin, I just find it a few days ago and it's just perfect for what I need... Unfortanetly in my MAC is not working well, don't let me export xml, don't let me apply solid materials, JUST LET ME VIEW IN WEBDIALOG and the most of the measures of elements oriented in Y axis appears in 0.00, did you or anyone mac users who are using this plugin can help?
                          thanks.
                          • Q Offline
                            QS3D
                            Excellent Plug-in!! How to I change the quantities to SF and CY (ft^2 & yards^3)??
                              tak2hata
                              Hi,camilozunga.
                              I will test the problem on mac.
                              Please wait. 😉
                              Hi,QS3D.
                              I made this plugin be using simply.
                              So there are only "meter" or "inch".
                              I will add selecting quantities units.(maybe units in Sketchup).
                              Please wait. 😉
                              Thanks.
                              by TAK2HATA
                              • Q Offline
                                QS3D
                                Looking forward to it. Thanks!
                                  camilozunga
                                  @tak2hata said:
                                  Hi,camilozunga.
                                  Please wait. 😉
                                  Hi,QS3D.
                                  Please wait. 😉
                                  Thanks.
                                  Thanks a lot for your answer, I'll be waiting.😄
                                    tak2hata
                                    Hi,All.
                                    I update to version2.2.
                                    Add Menu ,"Change Units" for reports.
                                    You can select every units of length , area , volume, cost.
                                    Hi,camilozunga.
                                    I tested solid quantify on mac.
                                    I could not found problem you sayed.
                                    Solid Quantify on Mac.
                                    Green line in this picture is Y-Axis.
                                    The entity was placedalong Y-Axis.
                                    Webdialog is fine.
                                    Please upload here skp file had problem and Screen capture of Webdialog.
                                    Or send it to me by message.
                                    Thanks.
                                    by TAK2HATA
                                    • kenK Offline
                                      ken
                                      tak2hata
                                      Great plugin. I have two questions, the COUNT(pc) what does this field indicate. And the cost, how do you get the cost field to reflect cost.
                                      As for the COUNT(pc) I have made duplicate's of solid, and the COUNT(pc) stays at 1, however it show each duplicate on a separate line.
                                      As for the COST, I have enter cost when I change the unit, as an example, 1.00 for each sq/in and the COST does not change.
                                      So I must be making a mistake just can't seem to track it down.
                                      Thanks you help and plugins.
                                      Ken
                                        tak2hata
                                        tak2hata
                                        Ken
                                        Hi,Ken.
                                        I improves count(pc) of component whitch have volumes.
                                        Now,The components have volumes is counted the figures up.
                                        And I add function to select the components want to be quantified.
                                        Look video in top thread of this.
                                        Thanks.
                                        by TAK2HATA
                                          Souto
                                          thanks.
                                          Great plugin however such as "Camilozunga" i' m not be able using it because won't let me export xml or cvs. I' m been trying with a simple file with a single cube with a basic material.
                                          I' m a Mac user also.
                                          Can you help me on this?
                                          Regards
                                          Souto
                                            mickath
                                            Hi All,
                                            I think this is a very useful plugin, but I do not understand how to use it despite after watching the videos, it will be more meaningful if those video include narration & explanation in sound.
                                            Mickath
                                            • 2 / 4
