    [Plugin]SOLID QUANTIFY v2.5.1 (20131215)
    64 Posts 19 Posters 64.8k Views 19 Watching
      tak2hata
      Dear Tak2hata:
      About It shows piece of component in Model info window ,this is not enough,because budgetary number need XML or EXCEL,Can you copy components number out to XML or EXCEL From MODEL INFO?
      In XML,not that every last Group or Component all need volume, area, length, piece,
      All Components only piece
      Partial Groups only length...For example:Angle iron,steel tube,pipe, and other section bar.
      Partial Groups only volume...For example:concrete...
      Partial Groups only area...For example:coating of wall;flooring tileon ground...notice:area of faces only that is to be Nominated inside groups,not all faces inside groups.
      Budgetary number is important a Part for BIM of project,in project,various material number is multifarious and disorderly,so all need exporting to XML or EXCEL.
      This things for BIM of sketchup,Expect Tak2hata and everybody substantial support.
      Thanks again!
      Hi,zfrps.
      Component counts will be solved with "component reporter+.rb"
      http://forums.sketchucation.com/viewtopic.php?t=1524#p6682.
      Budgetary pricing is important for quantify.
      It will be goal of this plugin.
      The setting of schema about Budgetary pricing list is needed.
      I will try it nearly future.
      Thanks.
      by TAK2HATA
        tak2hata
        Hi ,
        I update this tool in apr 05,2012.
        Add new functios.
        Enjoy! ๐Ÿ˜
        by TAK2HATA
          Always astonishing! ๐Ÿ‘
          • Z Offline
            ZFRPS
            First thanks your arduous jobs for everybody !
            NOW,01.jpgtest01.skp
            sketchup is bim
            • Z Offline
              ZFRPS
              So,about length of group,maybe i think first need a plugin:SOLIDGROUP TO LINEGROUP,then count length of linegroup,and when sketchup to CAD ,PIPE-linegroup very nice than solidgroup!
              Can you help me for plugin:SOLIDGROUP TO LINEGROUP?
              Thanks again !02.jpgtest02.skp
              sketchup is bim
                tak2hata
                Thanks again ![attachment=1:xrfumwyc]<!-- ia1 -->02.jpg<!-- ia1 -->[/attachment:xrfumwyc][attachment=0:xrfumwyc]<!-- ia0 -->test02.skp<!-- ia0 -->[/attachment:xrfumwyc]
                Hi, zfrps.
                I think it is very difficult.
                I will consider it future.
                Thanks.
                by TAK2HATA
                • O Offline
                  OSN58
                  What this number?
                  Thanks.
                    tak2hata
                    @osn58 said:
                    What this number?
                    Thanks.
                    Hi,OSN58.
                    "SUB TOTAL"is sub total of volumes in that group,when The Solids exists in the Group.
                    The group name is displayed in "PARENT NAME"
                    Thanks.
                    by TAK2HATA
                    • O Offline
                      OSN58
                      Sub total of COST in that group,when The Solids exists in the Group does not work?
                      Thanks.
                        tak2hata
                        Thanks.
                        Hi,I update solid quantify2 to v2.0b.
                        OSN58....
                        "Cost" in subtotal is incorrect.
                        It fixed now.
                        Thans.
                        by TAK2HATA
                        • O Offline
                          OSN58
                          Great plugin.
                          Thanks.
                          • O Offline
                            OSN58
                            How to make localization of a plug-in (on Russian)?
                              lyvirak
                              ใ‚ใ‚ŠใŒใจใ†ใ”ใ•ใ„ใพใ™ใ€‚
                              • H Offline
                                HenkW
                                This plug-in is great, but I found an error that renders the results unusable. Some of the material areas are doubled while most are correct in the generated reports. Secondly, in the the web dialogue there is a minor error that the volume is shown as "m" only in stead of "mยณ", while the distances are shown as "mยณ" in stead of just "m". If the first error regarding the incorrect doubling of areas could be fixed this plug-in would be perfect. Attached are a screen shot of the report as well as the SU model used to generate the report.
                                Sample report and SU model
                                • H Offline
                                  HenkW
                                  Screenshot of error report with wrong areas indicated.
                                    tak2hata
                                    Hi,Henk.
                                    Thanks for your helps.
                                    I will fix the problem in few days and update here.
                                    Thanks.
                                    by TAK2HATA
                                      tak2hata
                                      Hi,All and Henk.
                                      I update this.
                                      There are two Bugfix.
                                      Surface area calculated double,when that face do not have back-material.
                                      And mistaked about units when report rendered in webdialog.
                                      This problem fixed.
                                      Thanks.
                                      by TAK2HATA
                                      • H Offline
                                        HenkW
                                        TAK2HATA, you have done an awesome job with this plug-in! Thanks for the fix, we are pushing its abilities to the limit. It requires a lot of discipline to keep everything clean and tagged properly to get the required results. For those who are using this as well, when models get really big and you can't seem to find why there are still errors... Make sure that the axes of all groups in a multi-level component are identically aligned. Use in conjunction with the plug-in โ€œSolid Inspectorโ€ for quick results.
                                          camilozunga
                                          Hello and thanks for your plugin, I just find it a few days ago and it's just perfect for what I need... Unfortanetly in my MAC is not working well, don't let me export xml, don't let me apply solid materials, JUST LET ME VIEW IN WEBDIALOG and the most of the measures of elements oriented in Y axis appears in 0.00, did you or anyone mac users who are using this plugin can help?
                                          thanks.
                                          • Q Offline
                                            QS3D
                                            Excellent Plug-in!! How to I change the quantities to SF and CY (ft^2 & yards^3)??
                                            • 2 / 4
