    How to give edges a thickness?
    10 Posts 3 Posters 1.4k Views 3 Watching
    • andrea.biancoA
      andrea.bianco
      Let's say I have a volume defined by edges only (I erased the faces) and that I want to make its edges solid. Is there a plugin for giving edges a thickness? It would be even better to be able of choosing the shape that is used for the extrusion. I know I could use the follow me bu tselecting the whole set of edges won't do and working on separate sub-paths would lead to a huge time waste and give overlapping meshes where the follow-me surfaces of different paths cross. Any idea guys? ๐Ÿ˜„
      Andrea A. Bianco
      http://www.andreabianco.eu
      HW: i7 3.8GHz | nVidia GTX590 3GB | 8GB RAM
      SW: SketchUp, Octane, Adobe CC, Painter, Windows 8.1 64
      • thomthomT
        Profile Builder: http://www.smustard.com/script/ProfileBuilder
        • andrea.biancoA
          andrea.bianco
          Thanks for the fast response Thomas! I'm going to give it a try and post my impressions.
          Andrea A. Bianco
          • thomthomT
            It's payware, but worth it. I use it often when I work with profiles. Lots of pre-bundles shapes, and very easy to create new libraries.
            • andrea.biancoA
              andrea.bianco
              I'll happily buy it if it will do what I need ๐Ÿ˜„
              Do you think it can also manage a situation like this one?
              http://dl.dropbox.com/u/12003764/edges123.JPG
              As you can see in the highlighted part some vertices of the structure are part of more than two egdes.
              Andrea A. Bianco
              • thomthomT
                In those cases it will make each line segment individually I'm afraid.
                • andrea.biancoA
                  andrea.bianco
                  Too bad, though I can see a lot of power in that plugin and I could buy it the same. Working on separate edges will create a lot of weird overlapping, just like with the vanilla follow-me.
                  Andrea A. Bianco
                  • thomthomT
                    It does in fact use FollowMe under the hood. But the power is that it's parametric so you can go back and edit the path or profile at any time.
                    • mitcorbM
                      mitcorb
                      What about Lines to Tubes by Didier Bur, or Pipe Along Path, or Tube Along Path--Pipe and Tube by TIG? Bur's will allow individual groups for each individual segment on the line/curve. Lot of cleanup though. Finished profile can be 3 faces or more on all three scripts. And of course possibly Latticizer, by TIG? If this is what you mean by thickness.
                      • andrea.biancoA
                        andrea.bianco
                        Hi mitcorb, I tried some of them and no one can produce proper result with the situation in the screenshots - they all break where the 3 edges meet. Pipe Along Path is not processing the request , it complains because the edges are not a valid path. It could be I did something wrong when using the plugins, or maybe none of them is intended for this scenario.
                        The best results I got are the ones using Follow Me on various sub-paths and then intersecting and cleaning the mesh, which is still a viable choice if the mesh is simple but it becomes a no-no when things get too much complicated!
                        http://dl.dropbox.com/u/12003764/compedg.JPG
                        Andrea A. Bianco
