    Vray render error
    renderpluginsextensions
    5 Posts 3 Posters 12.9k Views 3 Watching
      JASTAR
      HI,
      Im rendering sketchup models with vray. This was working fine until yesterday. Then the render window starting showing a plain black screen with white dots (see screen shot). When i render the model using 'override material color' it comes out fine (see render).
      This has been such a problem that i have downloaded new sketchup and vrays in case of corruption. On new models it is generally ok, however rendering this same sketchup model causes the same problem - black render box with white dots.
      Does anyone know the problem?
      thank you,
      jacob
      • andybotA Offline
        andybot
        try loading your default vray options and do the rendering again. If that doesn't work, check if you have displacement map on any of your materials - that can sometimes cause the Light Cache pass to hang. In that case try turning off your displacement and use bump instead, see if it works.
          JASTAR
          Thanks for your response andybot.
          None of my materials had displacement maps on them. I have since changed all my materials to originate from the vray material editor rather than the SU material pallet. This seems to have done the trick.
          It still seems very odd that this was happening. Maybe a glitch with Vray?
          Cheers,
          jacob
          • andybotA Offline
            andybot
            sometimes I run into problems with materials if I am using components from the warehouse. I have to go through and check materials carefully.
            • V Offline
              valerostudio
              I get this issue all the time with displacement. Sometimes it takes hours to get the thing to start cranking along.
