    Edge mis-representation on iMac OS X Lion
    3 Posts 3 Posters 402 Views 3 Watching
    • P Offline
      PaulMalpas
      I have a problem with SU8 Pro on an iMac (i7, early 2011 model, ATI Radeon HD 4850 512 MB) running Mac OS X Lion 10.7.2
      Surfaces seem have a bleed-through, with a stub of the line and jagged edge of the texture visible overlapping the edge.
      This is an example - front surface
      front
      ...and behind the same junction
      Back side
      So the lines are in the right places, but the display does this. This is quite common at close-up work and is a problem when trying to be precise about the editing of interfaces.
      Any suggestions? Many thanks in anticipation.
      Paul
        driven
        hi Paul,
        it may be your settings, have your tested in different templates or styles, also parallel projection v perspective
        if you post an example skp as well it's easier for others to check your settings, etc...
        john
        • mariochaM Offline
          mariocha
          HUm... Strange.
          I cannot reproduce that.
          Have you tried selecting the objects and then checking entity info if the count is right ?
          Is Hardware acceleration checked in Preferences - OpenGL ?
          %(#008000)[Mario C.
