    Question about palettes
    22 Posts 4 Posters 2.4k Views 4 Watching
    • CadFatherC Offline
      CadFather
      Peace to all,
      i'm trying to make a button so that i can show/hide a panel (in this example the layers manager)
      in the google docs i found the following send action for toggling the visibility (though only pc) - Sketchup.send_action 21354
      this works on first click. however, once the panel is open, the next click will only minimise it and not hide it all together
      hunting for more found another command: Sketchup.send_action 21926
      this works by hiding\showing all panels
      and here i stopped as my genius already reached it's peak... how the heck do you combine the two beasts?
      PS can't believe i posted on the developer forum... πŸ˜†
      cmd = UI;;Command.new("Toggle Layers Panel") { Sketchup.send_action 21354 }
      cmd.large_icon = '#_ICONS/STANDARD/01_24.png'
      cmd.small_icon = '#_ICONS/STANDARD/01_16.png'
      cmd.tooltip = cmd.status_bar_text = "Toggle Layers Panel"
      gp_cd_standard_m_tb.add_item(cmd)
        Doesn't hide it all the way - also toggles toll up/down, but works on both platforms: UI.show_inspector( 'Layers' )
        http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#show_inspector
        For list of valid strings, use UI.inspector_names
        http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#inspector_names
          CadFather
          thanks Thom, so i should go the 'closeau' route....i'll check it out... just hope i can get them to hide at some point
            This code toggleWindows.rb is based on some ideas by Jim.
            It's useful for toggling the Outliner so it's rolledup, as it can cause splats during intensive processing if open...
            I've recently added the ' closeWindow' method.
            name='Layers' - or other window name.
            toggleRollUp(name) toggles the rollup of the window specified by 'name'.
            isRolledUp(name) returns true/false if window specified by 'name' is rolled-up/rolled-down.
            closeWindow(name) closes the window specified by 'name'.
            It required ' Win32API.so' I've attached a zipped version if you don't have it - unzip it into the Plugins folder...Win32API.ziptoggleWindows.rb
              CadFather
              Thanks master TIG - this is amazing!
              one last question..
              how would i have given two send action commands?
              just by this, and each command gets executed as the scripts is read down?
              def togz
                Your method should execute the two actions in order, BUT I've not tried it.
                It should first open Layers, or roll it up/down if it's already open.
                Then it would close all open palettes which is not what you really need ?
                I think you'd be better off opening the Layers palette with the first set of code... and then use the isRolledUp() test to roll it down with toggleRollUp() if it was already open and you code just rolled it up.
                E.G. Sketchup.send_action 21354 toggleRollUp('Layers') if isRolledUp('Layers')
                This ensures that the Layers palette window is opened and rolled down, even if it was already open but rolled up!
                Later when you are done with it use closeWindow('Layers') to close just that specified window...
                  CadFather
                  ok thanks TIG, it's going to be a full afternoon trying to get that in my head, but that example helps a lot! πŸ˜’ πŸ˜†
                  but if i get this right, there is no way to have just one button to fully show or fully hide the palette..
                  in previous versions it was easier..
                    Yes there is. πŸ˜’
                    You start the script running with a variable that persists across usages so to set it if the tools never been used yet...
                    When the user clicks the button the tool has these tests...
                    At the start @open is nil so use
                    ` if @open==1 ### it WAS clicked ON earlier, so it's probably ON
                    now check if it's open and close it if it is.
                    'close code'
                    but if it's already been closed [manually?] do nothing but this...
                    @open=0
                    else ### it's either been clicked OFF, or it has not yet been clicked at all
                    now check if it's closed and open it if it is.
                    'open code'
                    but if it's already open do nothing but this...
                    @open=1
                    end`
                    πŸ˜•
                      CadFather
                      wow...didn't know what i was asking...! 😲
                      I shall study it veery slowly.. Thanks TIG - you basically wrote it yourself..
                        CadFather
                        wow, this is terrible... just when i think i 'understand'...
                        this is the code:
                        def togz
                        name='Scenes'
                        toggleRollUp(name) if isRolledUp(name)  	### now check if it's open and close it if it is.
                        closeWindow(name) 	### 'close code'
                        ### but if it's already been closed [manually?] do nothing but this...
                        @open=0
                        togglecloseWindow(name) if iscloseWindow(name)  ### now check if it's closed and open it if it is.
                        Sketchup.send_action 21354 ### 'open code'
                        ### but if it's already open do nothing but this...
                        @open=1
                        end #def
                        and this is the error when i type togz into the ruby console...
                        Error: #<NoMethodError: undefined method `iscloseWindow' for main:Object>
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/- - togz.rb:14
                        (eval):155
                        i have placed both toggleWindows.rb and win32api.so in the plugins folder (and i saw there is a def called closeWindow in toggleWindows.rb) πŸ˜• πŸ˜• πŸ˜•
                          I've added a 'windowIsVisible(name)' test to the toggleWindows code.toggleWindows.rb This code below does what you want...
                          require 'toggleWindows.rb'
                            def toggleLayersWindow()
                              if @toggle==1
                                if windowIsVisible('Layers')
                                else
                                  Sketchup.send_action(21354)
                                @toggle=0
                              else
                                  if not @toggle ### 1st go
                                    else
                                  else
                                else
                                @toggle=1
                              end#if
                            end#def
                          πŸ€“
                            Along with a require 'toggleWindows.rb' to ensure it's loaded before accessing the code.
                              CadFather
                              that's not fair TIG - you're hacking your own code! πŸ˜†
                              i'll give it a spin..
                              ok folks, seriously what the heck have you got in those brains...i'm thinking of early retirement.. πŸ˜’
                              Thank You
                                Ain't no backing out now! πŸ˜‰
                                  CadFather
                                  you must be joking, i'm going out for a drink to forget!
                                    You'll be drinking binary
                                    • Dan RathbunD Offline
                                      Dan Rathbun
                                      Note that TIG's current example works on English Sketchup only. It needs a bit of work to retrieve the localized window titles from the exe's resources, in order to work for all language locale editions.
                                      I'm not here much anymore.
                                        CadFather
                                        that's true.. it works fine, but it greys out many context commands on starting SU... πŸ‘Ž
                                          How are you making the commands? - make one only attached to the toolbar.
                                          The reason for the grey-outs is 'too many commands'.
                                          It's possible to accidentally create a new command every time it's used...
                                            CadFather
                                            i went through most plugins commands, numbered them all differently (e.g. cmd1, cmd2, etc)
                                            also got rid of some plugins - right now it works - but i'm keeping an eye...
                                            many thanks again TIG... i owe you quite a few pints! πŸ˜„
                                            • 1 / 2
