    Question about palettes
    22 Posts 4 Posters 3.2k Views 4 Watching
    • CadFatherC
      CadFather
      ok thanks TIG, it's going to be a full afternoon trying to get that in my head, but that example helps a lot! πŸ˜’ πŸ˜†
      but if i get this right, there is no way to have just one button to fully show or fully hide the palette..
      in previous versions it was easier..
        Yes there is. πŸ˜’
        You start the script running with a variable that persists across usages so to set it if the tools never been used yet...
        When the user clicks the button the tool has these tests...
        At the start @open is nil so use
        ` if @open==1 ### it WAS clicked ON earlier, so it's probably ON
        now check if it's open and close it if it is.
        'close code'
        but if it's already been closed [manually?] do nothing but this...
        @open=0
        else ### it's either been clicked OFF, or it has not yet been clicked at all
        now check if it's closed and open it if it is.
        'open code'
        but if it's already open do nothing but this...
        @open=1
        end`
        πŸ˜•
        • CadFatherC
          CadFather
          wow...didn't know what i was asking...! 😲
          I shall study it veery slowly.. Thanks TIG - you basically wrote it yourself..
          • CadFatherC
            CadFather
            wow, this is terrible... just when i think i 'understand'...
            this is the code:
            def togz
            name='Scenes'
            toggleRollUp(name) if isRolledUp(name)  	### now check if it's open and close it if it is.
            closeWindow(name) 	### 'close code'
            ### but if it's already been closed [manually?] do nothing but this...
            @open=0
            togglecloseWindow(name) if iscloseWindow(name)  ### now check if it's closed and open it if it is.
            Sketchup.send_action 21354 ### 'open code'
            ### but if it's already open do nothing but this...
            @open=1
            end #def
            and this is the error when i type togz into the ruby console...
            Error: #<NoMethodError: undefined method `iscloseWindow' for main:Object>
            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/- - togz.rb:14
            (eval):155
            i have placed both toggleWindows.rb and win32api.so in the plugins folder (and i saw there is a def called closeWindow in toggleWindows.rb) πŸ˜• πŸ˜• πŸ˜•
              I've added a 'windowIsVisible(name)' test to the toggleWindows code.toggleWindows.rb This code below does what you want...
              require 'toggleWindows.rb'
                def toggleLayersWindow()
                  if @toggle==1
                    if windowIsVisible('Layers')
                      closeWindow('Layers')
                    else
                      Sketchup.send_action(21354)
                    @toggle=0
                  else
                      if not @toggle ### 1st go
                        if isRolledUp('Layers')
                          toggleRollUp('Layers')
                        else
                      else
                    else
                    @toggle=1
                  end#if
                end#def
              πŸ€“
                Along with a require 'toggleWindows.rb' to ensure it's loaded before accessing the code.
                • CadFatherC
                  CadFather
                  that's not fair TIG - you're hacking your own code! πŸ˜†
                  i'll give it a spin..
                  ok folks, seriously what the heck have you got in those brains...i'm thinking of early retirement.. πŸ˜’
                  Thank You
                    Ain't no backing out now! πŸ˜‰
                    • CadFatherC
                      CadFather
                      you must be joking, i'm going out for a drink to forget!
                        You'll be drinking binary
                        • Dan RathbunD
                          Dan Rathbun
                          Note that TIG's current example works on English Sketchup only. It needs a bit of work to retrieve the localized window titles from the exe's resources, in order to work for all language locale editions.
                          I'm not here much anymore.
                          • CadFatherC
                            CadFather
                            that's true.. it works fine, but it greys out many context commands on starting SU... πŸ‘Ž
                              How are you making the commands? - make one only attached to the toolbar.
                              The reason for the grey-outs is 'too many commands'.
                              It's possible to accidentally create a new command every time it's used...
                              • CadFatherC
                                CadFather
                                i went through most plugins commands, numbered them all differently (e.g. cmd1, cmd2, etc)
                                also got rid of some plugins - right now it works - but i'm keeping an eye...
                                many thanks again TIG... i owe you quite a few pints! πŸ˜„
                                • CadFatherC
                                  CadFather
                                  ok, updated version with better commands and icons. works fine on my pc
                                  TogglePanels.zip
                                  • CadFatherC
                                    CadFather
                                    yes, maybe i'm better at it after a few guinness...
                                    meantime here's the result - i don't have a mac so do not know whether it works there.
                                    only thing is that upon reopening, the windows always dock at the bottom of the stack.. πŸ˜’
                                    Cheers
