    Reflect enviroment on windows
    renderpluginsextensions
    12 Posts 5 Posters 3.4k Views 5 Watching
      anthonyaltamiranos
      Hi. I'm creating a hotel render with lots of windows, so I would like to show clouds or an enviroment reflected on those mirrors but I can't.
      I tried using an HDRI image but I couldn't make it work.
      Please help. I tried everything.
      I attached an image preview.
      I'm also having problem whit the reflections. As you can se, the grass isn't reflected on the windows.
      Thanks in advance for your help,
      Anthony
        anthonyaltamiranos
        Sombody please. I have tried everything without success.
        • mitcorbM Offline
          mitcorb
          How was the reflection effect in the pool accomplished? Would it be the same for the glass panels? I must say I have not done any technical rendering. I only have a vague idea of the workflow. Perhaps that pool reflection is merely a texture?
            anthonyaltamiranos
            The pool texture was accomplished by using a bump map and a reflection.
            The windows are different. Just reflection and a little transparency. What I would like is to have a background with clouds or a landscape so it could be reflected on the windows.
            If you see, the windows are reflecting a solid environment but I would like to reflect a landscape or clouds.
            • mitcorbM Offline
              mitcorb
              Then my guess is you need a skyvault or a surround with sky image on it, maybe it needs to be illuminated and the illumination raytraced to the glass. Still only guessing.
              • N Offline
                nomeradona
                These links will help
                1. reflecting surrounding on glasses
                  http://sketchupvrayresources.blogspot.com/2011/07/tutorial-glass-reflecting-surrounding.html
                2. Reflection on glass glazings
                  http://nomeradona.blogspot.com/2011/05/reflection-on-glass-glazings.html
                3. baking material on glasses
                  http://sketchupvrayresources.blogspot.com/2011/06/trick-quickly-baking-reflections-using.html
                visit my blog: http://www.nomeradona.blogspot.com
                • N Offline
                  nomeradona
                  I think you need this water pool tutorial too http://nomeradona.blogspot.com/2011/09/tutorial-how-to-create-pool-water-in.html
                    anthonyaltamiranos
                    Thanks a lot the both of you.
                    I'll take a look at those links and I'll let you know.
                    • O Offline
                      OSN58
                      If you see, the windows are reflecting a solid environment but I would like to reflect a landscape or clouds.[/quote]
                      2. enable the option "Exclude all objects from reflection"
                        anthonyaltamiranos
                        Thanks a lot OSN58.
                        Now I could add a background reflection easily just as you explained.
                        I'm experimenting a problem that I use to have a lot. Some textures aren't reflecting on the windows.
                        I have searched for a solution everywhere but I couldn't find it. Please help me fix this.
                        • mitcorbM Offline
                          mitcorb
                          @nomeradona:
                          Thanks for coming to the rescue. 👍
                            rspierenburg
                            You should check to make sure the material on the ground is applied to the outside (white) face of the plane. I believe if it is applied to the back face it messes up Vray in some instances.
                            Note the Blue 'reversed' face
                            Note the reflection in the metal chrome material
