    Reflect enviroment on windows
    renderpluginsextensions
    12 Posts 5 Posters 3.9k Views 5 Watching
    • mitcorbM
      mitcorb
      How was the reflection effect in the pool accomplished? Would it be the same for the glass panels? I must say I have not done any technical rendering. I only have a vague idea of the workflow. Perhaps that pool reflection is merely a texture?
        anthonyaltamiranos
        The pool texture was accomplished by using a bump map and a reflection.
        The windows are different. Just reflection and a little transparency. What I would like is to have a background with clouds or a landscape so it could be reflected on the windows.
        If you see, the windows are reflecting a solid environment but I would like to reflect a landscape or clouds.
        • mitcorbM
          mitcorb
          Then my guess is you need a skyvault or a surround with sky image on it, maybe it needs to be illuminated and the illumination raytraced to the glass. Still only guessing.
          • N
            nomeradona
            These links will help
            1. reflecting surrounding on glasses
              http://sketchupvrayresources.blogspot.com/2011/07/tutorial-glass-reflecting-surrounding.html
            2. Reflection on glass glazings
              http://nomeradona.blogspot.com/2011/05/reflection-on-glass-glazings.html
            3. baking material on glasses
              http://sketchupvrayresources.blogspot.com/2011/06/trick-quickly-baking-reflections-using.html
            • N
              nomeradona
              I think you need this water pool tutorial too http://nomeradona.blogspot.com/2011/09/tutorial-how-to-create-pool-water-in.html
                anthonyaltamiranos
                Thanks a lot the both of you.
                I'll take a look at those links and I'll let you know.
                • O
                  OSN58
                  If you see, the windows are reflecting a solid environment but I would like to reflect a landscape or clouds.[/quote]
                  2. enable the option "Exclude all objects from reflection"
                    anthonyaltamiranos
                    Thanks a lot OSN58.
                    Now I could add a background reflection easily just as you explained.
                    I'm experimenting a problem that I use to have a lot. Some textures aren't reflecting on the windows.
                    I have searched for a solution everywhere but I couldn't find it. Please help me fix this.
                    • mitcorbM
                      mitcorb
                      @nomeradona:
                      Thanks for coming to the rescue. 👍
                        rspierenburg
                        You should check to make sure the material on the ground is applied to the outside (white) face of the plane. I believe if it is applied to the back face it messes up Vray in some instances.
                        Note the Blue 'reversed' face
                        Note the reflection in the metal chrome material
