    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 105.0k Views 35 Watching
      Aerilius
      I found the bug and fixed it. The backtraces became lost because of a rescue Exception.
        Thanks for that. 😄
        Though ... I broke it again... 😕
        Error #<NoMethodError;undefined method `entities' for #<Sketchup;;ComponentInstance;0x773ec0c>.>
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;253;in `initialize'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `call'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `initialize'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `each'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `new'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `process'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;188;in `options_dialog'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `call'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `show_modal'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `options_dialog'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;114;in `run'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;61
        It appear you're trying to use ComponentInstance.entities which doesn't exist in the API - all though a few plugins add this method to the ruby classes.
          Changed line 253 to:
          definition.entities.each{|e| block.call(e, s*scale)}
          Working! 😄
            Here's the list of material in a model where I needed to size down the textures:
            Before:
            === TEXTURE MATERIALS BY SIZE ===
            Material4
              Size; 4000x4000 pixels
              Size; 45.78 MB estimated uncompressed RGB
              Size; 61.04 MB estimated uncompressed RGBA
              Path; C;/Users/ktn/AppData/Local/Temp/VfSTextureCache
            Material13
            Material3
              Size; 2255x1782 pixels
              Size; 11.50 MB estimated uncompressed RGB
              Size; 15.33 MB estimated uncompressed RGBA
            Material14
            Material1
              Size; 2048x1536 pixels
              Size; 9.00 MB estimated uncompressed RGB
              Size; 12.00 MB estimated uncompressed RGBA
            black3
              Size; 2814x850 pixels
              Size; 6.84 MB estimated uncompressed RGB
              Size; 9.12 MB estimated uncompressed RGBA
              File; glass.psd
              Path; E;\LIBRARY\DIGITAL LIBRARY\MORQ LIBRARY TEXTURES\Emiliano
            black1
              File; glass.psd
            treverk1
              Size; 1500x1500 pixels
              Size; 6.44 MB estimated uncompressed RGB
              Size; 8.58 MB estimated uncompressed RGBA
            treverk2
            Material15
              Size; 1416x1416 pixels
              Size; 5.74 MB estimated uncompressed RGB
              Size; 7.65 MB estimated uncompressed RGBA
            Material8
              Size; 1417x1408 pixels
              Size; 5.71 MB estimated uncompressed RGB
              Size; 7.61 MB estimated uncompressed RGBA
              File; Material8_extractedTex7662.tif
            Material16
              File; Material16_extractedTex62.tif
            Material5
              Size; 1000x975 pixels
              Size; 2.79 MB estimated uncompressed RGB
              Size; 3.72 MB estimated uncompressed RGBA
            Material30
            Then I ran the script, got some messages:
            black1; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
            black3; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
            I assume PDS files are not supported?
            After:
            black3
              File; glass.psd
            black1
              File; glass.psd
            Material15
            treverk1
              Size; 512x512 pixels
              Size; 768.00 KB estimated uncompressed RGB
              Size; 1.00 MB estimated uncompressed RGBA
              Path; C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480
            Material4
            treverk2
            Material13
            Material16
              Size; 512x508 pixels
              Size; 762.00 KB estimated uncompressed RGB
              Size; 1016.00 KB estimated uncompressed RGBA
            Material8
            Material5
              Size; 512x499 pixels
              Size; 748.50 KB estimated uncompressed RGB
              Size; 998.00 KB estimated uncompressed RGBA
            Material30
            Material3
              Size; 512x404 pixels
              Size; 606.00 KB estimated uncompressed RGB
              Size; 808.00 KB estimated uncompressed RGBA
            Material14
            Material1
              Size; 512x384 pixels
              Size; 576.00 KB estimated uncompressed RGB
              Size; 768.00 KB estimated uncompressed RGBA
            Notice Material15 which is a PNG still is larger than 512px. Why is that? There was no messages about this file.
              Aerilius
              It seems SketchUp's texture writer does not write psd files. In that case, I'll probably force a default extension.
              I have no idea what could cause to skip Material15. Is it reproducible? Can you send me a file with that material and its geometry (and group nesting...).
                It's 8MB (after removing the two PSD textures)
                PM me your email address and I'll send it to you.
                  Aerilius
                  I think I have fixed it now.
                  Also the texture writer can export PSDs (I have no idea why these failed), but it can't convert psd into other formats by setting a different file extension.
                    Does the texture resizer change the format?
                      Aerilius
                      Here not.
                      But the underlaying ImageMagick.rb has the option to (temporarily) change lossy formats into lossless bmp. I use that in another plugin, mainly because bmps process much faster.
                      • OxerO Offline
                        Oxer
                        I have installed the last version of the plugin (1.4.3 for Mac OSX) and when i run SU it appears a Console Error:
                        I work on OSX 10.8.2, SU 8 Pro
                        http://www.oxervision.blogspot.com/
                          Aerilius
                          I fixed it (1.4.4). Sorry, it was a merging mistake.
                          • OxerO Offline
                            Oxer
                            I have installed the 1.4.4 version for Mac OSX and when I call to the plugin the boxes input are empty, I select Percentage, I introduce 50%, after I push Apply button then it appears this Error in Console Ruby:
                            I have translated the plugin to spanish language but the plugin window's is in English.
                            Spanish Language for Texture Resizer
                            Mac OSX 10.8.2, SU Pro 8
                              Aerilius
                              I think I have now found the issue. Can you try to download it again?
                              And many thanks for the translation!!!
                              [I thought I had posted this reply yesterday, I don't know how it got lost.]
                              • OxerO Offline
                                Oxer
                                I have reinstalled the 1.4.4 version and the plugin runs fine (the translation works ok), but when i push Apply button it appears the icon Processing... and in the Ruby console this message:
                                I have seen a skp_textureresizer94750 folder in this path /private/var/folders/2y/lg9fyd494rddw7s_xr5zz2yr0000gn/T/skp_textureresizer94750 but only It contains one image.
                                I hope you can help me, if you need more info, tell me it.
                                Mac OSX 10.8.2, Sketchup 8 Pro
                                Happy New Year!! 😄
                                New Spanish Language file.
                                TextureResizer_ES.strings.zip
                                  Aerilius
                                  I published the new version 1.4.5
                                    Aerilius
                                    Small update (1.4.7):
                                    • added icon
                                    • OxerO Offline
                                      Oxer
                                      I can't see the icon in Mac OSX 10.8.2, the plugin (1.4.7) works fine only the icon problem. Non Ruby console Error.
                                        Aerilius
                                        Menus don't have icons. The plugin doesn't include a (one button) toolbar, but an icon is the pre-condition for any future toolbars 😉
                                        • OxerO Offline
                                          Oxer
                                          I have added one line to the TextureResizer. rb and now i can see the icon plugin. This is the line:
                                          "UI::Toolbar.new(@@translate["Resize Textures").add_item(cmd_resize)]"
                                          This line go after this line: " UI.menu("Plugins").add_item(cmd_resize)"
                                          Thanks for the icons!!
                                          PS: The plugin works fine, when you push the icon, it appears the plugin's window. 👍
                                          • P Offline
                                            paolo
                                            I should be missing something cause I have got make Unique Texture++ and Texture Resizer, the last one is not doing anything.
                                            I have been using Goldilocks v2.0 to help me notice what textures to are too big on view.
                                            Could some one tell me whats wrong with Texture Resizer? there is any other plugin? how can I choose better texture size?
                                            Thx
                                            • 6
                                            • 4 / 6
