    Painted metal texture needed
    9 Posts 7 Posters 2.8k Views 7 Watching
    • holmes1977H
      holmes1977
      Hi all
      I'm looking for a texture like the one in this picture done by Sharek. I'm using Thea and Vray to render. I presume its just a bump map and reflection map. Does anyone have anything like this they would like to share.
      http://fc09.deviantart.net/fs70/f/2011/145/0/e/t34_85mm_tank_detils_by_shareck-d3h7r1e.jpg
      Exaggeration makes a dull story better.
      • D
        dsarchs
        I've cobbled textures together for this before but never come up with anything I've really liked. In kerkythea a mix of procedurals isn't too bad, but I'd be interested in a good texture myself.
        I'd also be interested in a texture similar to this (camera surface).
        Knowledge is a polite word for dead but not buried imagination.
        -e.e.cummings
          Pete shared a great plastic thea material awhile back. I'll try hunt it down as it has a great bump for this stippled look
          • N
            notareal
            For stippled look you naturally need a suitable bump map. But you can use the same bump maps as a roughness map (or reflection/specularity/... -map, up to renderer). In Thea, the white part of roughness map do increase roughness, so you need to invert map.
            • urgenU
              urgen
              ...holmes1977,These maps are made of different textures of plaster walls ... Google's search and PixPlant help you ...it is not difficult πŸ˜‰
              ...See here for an example...
              http://www.openfootage.net/?p=119
              --pupil forever...------
              • Bob JamesB
                Bob James
                @urgen
                Question displaying maximum ignorance:
                Since most of the textures are not tileable (and are not by their very nature possible to make tileable), how do you use them on a surface since they would create just a series of identical patches?
                • Chris FullmerC
                  That's always my question as well.
                  All my Plugins I've written
                  • urgenU
                    urgen
                    ...guys, this is Max Vray(Shareck hinted about it ) .... Wrap textures(maps) .... ... they are made in Max Vray, edited in Photoshop (I think use of plaster (stucco) wall texture), and inserted back into the render ...
                    • holmes1977H
                      holmes1977
                      Thanks all for your help
