    Painted metal texture needed
    9 Posts 7 Posters 2.6k Views 7 Watching
    • holmes1977H Offline
      holmes1977
      Hi all
      I'm looking for a texture like the one in this picture done by Sharek. I'm using Thea and Vray to render. I presume its just a bump map and reflection map. Does anyone have anything like this they would like to share.
      http://fc09.deviantart.net/fs70/f/2011/145/0/e/t34_85mm_tank_detils_by_shareck-d3h7r1e.jpg
      Exaggeration makes a dull story better.
        dsarchs
        I've cobbled textures together for this before but never come up with anything I've really liked. In kerkythea a mix of procedurals isn't too bad, but I'd be interested in a good texture myself.
        I'd also be interested in a texture similar to this (camera surface).
        Knowledge is a polite word for dead but not buried imagination.
        -e.e.cummings
        • Rich O BrienR Online
          Pete shared a great plastic thea material awhile back. I'll try hunt it down as it has a great bump for this stippled look
          • N Offline
            notareal
            For stippled look you naturally need a suitable bump map. But you can use the same bump maps as a roughness map (or reflection/specularity/... -map, up to renderer). In Thea, the white part of roughness map do increase roughness, so you need to invert map.
            • urgenU Offline
              urgen
              ...holmes1977,These maps are made of different textures of plaster walls ... Google's search and PixPlant help you ...it is not difficult πŸ˜‰
              ...See here for an example...
              http://www.openfootage.net/?p=119
              --pupil forever...------
              • Bob JamesB Offline
                Bob James
                @urgen
                Question displaying maximum ignorance:
                Since most of the textures are not tileable (and are not by their very nature possible to make tileable), how do you use them on a surface since they would create just a series of identical patches?
                • Chris FullmerC Offline
                  That's always my question as well.
                  • urgenU Offline
                    urgen
                    ...guys, this is Max Vray(Shareck hinted about it ) .... Wrap textures(maps) .... ... they are made in Max Vray, edited in Photoshop (I think use of plaster (stucco) wall texture), and inserted back into the render ...
                      holmes1977
                      Thanks all for your help
