π¨ Skimp | 25% Off until March 30 Buy Now
Plugin for simplifying geometry?
I am searching in the "plugin index" for a plugin to simplify my geometry.
For instance: I've imported a .3ds file from a chair, which has a lot of faces.
I would like to simplify this model by just using a plugin.
Like when i should use it on a cilinder with 12 faces, i could reduce it to a cilinder with 6 faces.
Is this possible and is there a plugin i can use from the Plugin Index?Thx
Dale's Polyreducer ought to fit the bill.
If you've cash to spend there's also TGI3D and MoolTools. If you've a king's ransom there's Deep Exploration.
