    [Plugin] SolidSolver
    129 Posts 40 Posters 119.7k Views 40 Watching
    • bmikeB
      bmike
      @tig said:
      It is - http://sketchucation.com/pluginstore?pln=TIG_solidsolver
      And it works just fine in v2014.
      Many such Plugins needed no adjustment to be compatible...
      A simple search in the PluginStore's own Search box is a powerful ally... πŸ˜‰
      Please don't move Plugins over from an earlier SketchUp version [unless you really have to!]: get the latest Plugins version that is available - some Plugins have had to be reconfigured to also work in v2014, whilst a few others still need fixing [hopefully none of mine?].
      well, all that came up was your manifold plugin. but i found it. had to add a space between solid and solver. and then scroll down a bit.
      πŸ˜‰
      thanks.
      mike beganyi design + consulting llc
      • TIGT
        Sometimes you need to think what you are searching for... and split compounded names...
        That said SolidSolver WILL work in the search [because I just renamed the Plugin's title in the database πŸ˜‰ ]
        • D
          deskpilot
          Hi TIG, greetings from South Australia. Your plugin is just what I need but, when I download it, I get this notification in my download page:
          TIG_solidsolver_v2.2.rbz
          That seems fine but when I click on it to open it, I get the usually 'windows can't read this etc' So how do I load it into SU2014 on win7 64bit system?
            rename it in TIG_solidsolver_v2.2.zip
            unzip
            and put the result in the Plugins folder!
            This last one can be in different place following your Windows system!
            • TIGT
              No need to faff on with RBZ to ZIP etc.
              In all SketchUp versions since v8M2 you just have to use the purpose-built native-tool from the Preferences > Extensions > Install... button... to get the contents of any RBZ directly installed into your default Plugins folder, and loaded...
              • TIGT
                Here's an updated version that also tries to fix intersecting forms - which might appear initially 'solid' but have intersecting faces, and will mess up 3d-printing...
                v3.0...
                • TIGT
                  Here's an update to v3.1 http://sketchucation.com/pluginstore?pln=TIG_solidsolver
                  It corrects some typos with the code. 😳
                  It should now correctly find intersections, holes, flaps, partitions etc and try to correct these and make a selected group or instance a proper 3d-printable solid... πŸ€“
                  • pbacotP
                    It was already great! Now new and improved! Thanks TIG!
                    • TIGT
                      Here's v3.2
                      It is now faster, more robust, and resolves intersecting forms, partitions, and reversed faces better...
                      • TIGT
                        Here's v3.3
                        There's a fix for an intersection glitch when solving multiple groups in succession, and the resulting edges were sometimes getting transformed inappropriately...
                        • cottyC
                          cotty
                          Thank you for the nice updates!
                          my SketchUp gallery
                          • TIGT
                            Here's v3.5 http://sketchucation.com/pluginstore?pln=TIG_solidsolver
                            [we skipped v3.4 !]
                            It fixes some face and tiny folded face failures - which might rarely need two tries to end up with a successful 'solid' !
                            • cottyC
                              cotty
                              I've tried with an group with some nested components, confirmed the question if I want to explode them, but they are still there afterwards...
                              (model here: http://blog.cotty.de/2015/04/pfosten/)
                              my SketchUp gallery
                              • TIGT
                                Thanks for the report.
                                I suspect what happens is that it's not a solid because it contains nested containers.
                                So you elect to explode them.
                                SolidSolver then does a test to see if any part of the geometry intersects - it may report 'solid' be be unprintable in 3d !
                                Having done the check it reports your model is already solid, but at that point it undoes its intersection check, which undoes the exploding too...
                                I can fix it, just needs a convoluted check/trap...
                                Watch for an update asap...
                                • TIGT
                                  Following Cotty's report...
                                  Here's v4.0 http://sketchucation.com/pluginstore?pln=TIG_solidsolver Any nested contents will now stay exploded after the ensuing intersecting-faces check, leaving a true-solid.
                                  The processing speed has also been greatly improved by recoding the intersecting-faces checker.
                                  • cottyC
                                    cotty
                                    Thank you for the fast update, improvement confirmed!
                                    my SketchUp gallery
                                    • TIGT
                                      Here's v4.1 http://sketchucation.com/pluginstore?pln=TIG_solidsolver A rare fail with tiny hole healing has been resolved.
                                      • J
                                        jtri
                                        When I ran Solid solver on a component in this model I would get a bug splat. I fixed all my components so that they are solids and ran Solid Solver and still go a bug splat. Any ideas? I am using Ver 8 of SketchUp.
                                        15.4.5 bigger bottom stay.skp
                                        • D
                                          driven
                                          some of your geometry is on the Bottom Stay layer, move it to Layer 0 and it's solid...
                                          john
                                          • J
                                            jtri
                                            Thanks! I did not see that.......
                                            • 6
                                            • 7
                                            • 5 / 7
