    [REQ] GoogleEarth Meshes boolean subtract
    49 Posts 10 Posters 11.7k Views 10 Watching
      AcesHigh
      Hi all... I am working right now on a model where I need to import a huge number of GoogleEarth meshes.
      As we all know, you cant perfecly import from GoogleEarth, when you import several meshes, they will usually overlap over each other in several places.
      This overlapping causes textures problems.
      But you cant boolean subtract one from the other.
      I tried the plugins 2D Boolean (which joins the meshes) and Cleanup³. None solved the overlapping problem, as can be seen below.
      http://img266.imageshack.us/img266/5064/coplanarfaces2.jpg
      What am I doing right now? I am using ZORRO to subtract the overlapping parts. But its impossibly huge work, when you have to do it in a model with hundreds of GoogleEarth imported parts. Zorro around the imported area of one mesh, carefully select the triangles you want to delete, manually erase triangles left. Repeat 100 times.
      What would make it EASIER the work for people working with lots of GoogleEarth imported meshes?
      A kind of boolean subtract, even if not a real boolean subtraction, specially because yes, there is the possibility some faces are not really coplanar and not all vertices of different meshes meet.
      What can be done then? Imagine two meshes. They are 2d. The plugin should draw imaginary boxes around one mesh, and subtract the shape of this box from the other mesh.
      Done, no more overlapping mesh geometry interfering with textures and everything else.
      Can this be done? Thanks.
      • mitcorbM Offline
        mitcorb
        I have only used the free version of Google Earth for basic purposes, and do know that the Pro Version has some additional capabilities. Your suggestion would be an excellent Native feature, at least in the Pro Version, and would be ideal as native to both versions. Anyway, I vote yes for a plugin like this.
        • CadFatherC Offline
          CadFather
          i use TIG's drop vertices http://forums.sketchucation.com/viewtopic.php?t=39251
          then Didier's http://forums.sketchucation.com/viewtopic.php?t=29126#p253563 to recreate the mesh
          then drape the borders of the terrains onto the new mesh and project the images onto it.
          if the image detail is not so important, you can use a zoomed out view of the whole area (either from GE or stitched later) and paint it over the mesh.
            AcesHigh
            thanks, but terrain detail and image detail are important. And when zooming out to get larger areas, you lose both. Didier´s mesh recreation tool loses the image and you have to project it again... very hard when dealing with many different meshes.
            my plugin request is not even that difficult I suppose. It doesnt join any mesh nor anything. Just cut one mesh from the other, like a Zorro and delete, automatic, when looking parallel camera from the top!
            thanks
              Are you still using SU7/7.1?
              There's better elevation info from Google Maps which is accessed through SU8. Maybe that would eliminate your problems.
              This is an import from Google Maps of two neighboring sections. I cut the geometry from the smaller section and pasted it into the larger one to check for overlapping faces. There are none.
              And with textures on you can see by the difference in resolution these were at different zoom settings. I didn't need a plugin for any of this.
              Why don't you add your SU version and OS to your profile?
              • jolranJ Offline
                jolran
                2d boolean only works on "flat" geometry, I'm afraid.
                Hint, the name: 2D boolean.
                I suspect a terrainmesh is a "3d geometry". Even though it's just a surface you would have to base calculations of 3 dimensions cause of elevations and such.
                Maybe you could build a box "underneath" the surface and do standard boolean on that?
                  Can't you simply group the two mesh groups together and explode them together inside the new group - then use one of the many erase-coplanar-edges tools available or manually erase unwanted edge divisions...
                  • Chris FullmerC Offline
                    What if the plugin sort of turned the terrains into volumes by drawing vertical faces downards on the sides, and then a face on the bottom to close the whole thing off into a sketrchup solid. Then use the solid tools to boolean add them together.
                    That could work. It would be a plugin for pro users only though because of the solids tools usage. And I'm not sure how smart it would be about the GE image emerging. But it could work......maybe.
                    All my Plugins I've written
                      AcesHigh
                      no, I am using SU8
                      quite the contrary. The problem is even bigger with SU8.
                      with SU7, you could get a piece from GoogleEarth, than use the arrow keys to go sideways, and you could get two pieces that would overlap in just one side.
                      with SU8, you dont use GoogleEarth. Everytime you go grab a new terrain mesh, the screen resets to the original land piece position, and you cant scroll with the arrow keys... you must scroll with the mouse, sometimes the next piece will be a little up, or a little down, as well as overlapping on the sides.
                      [attachment=1:m8rijg4r]<!-- ia1 -->G Maps1.png<!-- ia1 -->[/attachment:m8rijg4r]
                      they are overlapping a bit on the last row of triangles. The textures will flicker since they are coplanar faces.
                      Windows 7, SU8.
                      yes, I know. I used the 2d Boolean plugin. But it doesnt subtract one from the other. It joins the two meshes. The coplanar faces remain. As I showed in screenshot above.
                      oh, I see where you are getting
                      not practical when you have to deal with dozens or hundreds of different meshes.
                        AcesHigh
                        already tried it, both with 2D Boolean (which joins the two groups into one with everything exploded inside) and also by joining the two groups and exploding the stuff inside.
                        then using CleanUo³. For some reason, the coplanar faces of meshes do not disappear.
                          AcesHigh
                          maybe it could work. It doesnt even need to be a real boolean. Wait a bit, I will try to draw what I imagined.
                            There weren't any overlapping faces in the example I posted and no flickering as I orbited
                              AcesHigh
                              two different meshes with overlapping parts. Notice the bounding boxes. Imagine the bounding boxes as the areas where one mesh should be cut from the other.
                              http://img830.imageshack.us/img830/4519/13678112.jpg
                              MAYBE the bounding boxes for the operation should be a bit higher and lower than the real ones, I dont know... if the lowest or highest areas of the mesh are in the border, the cut between two meshes would be more "garanteed" if the bounding box was a bit larger in the vertical?
                              http://img716.imageshack.us/img716/3616/56366146.jpg
                              subtract one mesh from the other. In the example, I simply deleted the triangles, but this doesnt work in real life, because the triangles in one mesh dont quite match the triangles from the other mesh, and a gap between the two meshes may appear (or they still may overlap).
                              the perfect solution is to ZORRO out one mesh from the other and then delete the overlapping triangles.
                              I imagine one bounding box exactly ZORROING through the other mesh, and then all the parts of the second mesh, which are inside the first mesh bounding box, being deleted.
                              http://img62.imageshack.us/img62/6118/77524624.jpg
                                AcesHigh
                                http://img542.imageshack.us/img542/4412/89340841.jpg
                                to me, it seems clear the red marked area is overlapping each other... there is a mix of dark and light green triangles there, thats usually what happens when there is overlapping faces, and when you orbit, there is flickering between the triangles, since the program doesnt know if it displays the triangles of one or the other mesh.
                                if it didnt happen to you, you were lucky. I made several tries with both Sketchup 7 and 8 and it always happens.
                                either way, you have only two meshes, so only a small part of each mesh overlaps the other. Its easy to overlap so little when you have only two small meshes. When you try to mount a giant gigsaw puzzle by having to select dozens of different meshes, you will end up with huge parts overlapping each other, and you will see the flickering when getting near and moving the camera (or even when importing to other program and rendering)
                                  As I recall, what Google had said about importing GE terrains in SU8 is that now it is much more accurate, because it now imports the actual Google Earth geometry. So therefore, terrains should match up perfectly.
                                  So when you import adjacent terrains, even if they are net perfectly aligned, the vertices should align perfectly, because it is importing the Google Earth geometry.
                                  The one MAJOR exception is that they limit the amount of vertices imported to 1,000. So if the snapshot includes more than 1,000 vertices, then SU will use its own algorithm to simplify the mesh. This simplification can reduce vertices, move their position on the x,y AND Z directions, and that will cause the overlapping vertices to not align.
                                  I had written a tool at one point that would help test it the terrain had been downsampled by SketchUp, so I would know that I needed to zoom in closer to get a higher resolution terrain. Because again, theoretically, if SketchUp does not downsample the terrain, then the vertices really should align perfectly.
                                  I'm not completely sure that all of the above is true. It is largely my recollection of what they had told us.
                                    AcesHigh
                                    hi Chris. I just imported two small GoogleEarth meshes, using Sketchup 8.
                                    600 triangles each (i suppose... each one had 300 faces).
                                    still no luck. There was overlapping and nope, the triangles from each mesh did not mach perfectly the triangles from the other mesh.
                                      Well, there goes that theory! Did you try the manual way I described? Maybe I'll try that right now.
                                        bleah, the edges are not necessarily co-planar. So its not easy to drop vertical lines at the corners and turn the thing into a big cube.
                                        Bummer,
                                        Chris
                                          AcesHigh
                                          Bummer,
                                          Chris
                                          I would give you some suggestions... if I even knew what you mean 💚
                                          doesnt Sketchup have absolute world coordinates? Wouldnt the vertical lines just drop till a specific absolute world coordinate, at all 4 corners of an imported mesh? 😳
                                          • sdmitchS Offline
                                            sdmitch
                                            Here is how I did it. I created and grouped the four vertical faces surrounding the 1st terrain mesh using the bounding box corners. Then I did an intersect_with the faces and the 2nd terrain group and added the intersection entities to the entities of the 2nd terrain group. I then searched the entities of the 2nd terrain group for hidden edges that fell within the bounds of the 1st terrain group and deleted them.
                                            http://sdmitch.blogspot.com/
                                            • 1 / 3
