    Using "Save As" to create a new file?
    3 Posts 2 Posters 269 Views 2 Watching
      bob-designer
      Used "Save As", created a copy of File-1, including a new file name, File-2. I deleted the parts of the model grouped on different layers of File-2 the whole model is now back on layer0. The problem is, that deleteing the layers on File-2 also deleted the layers on File-1. Where Did I go wrong?
      Thanks for your help, Bob
        This should not happen.
        Are you sure you did it that way ?
        Can you supply SKPs etc ??
          bob-designer
          I have used the "Save As" command many times in the past, without problems. I have made about 15 incremental copies of File-1, in order to make design changes to the model; that way I can fall back to the saved copy, if needed. The only difference with File-2, is that I "moved" the groups back to layer0. I did this to purge and clean up the model before starting the rendering process. I have not started the purge and file cleaning process, however, I did explode the whole model once it was on layer0. I have a problem with posting the 3d design model file; because the model is a house design that will be for sale. Intellectural property (copyright)thing. If there is a way of posting my designs on the forum without losing my rights to the design; I would love to share then with the members. TIA, Bob
