    Drape WITH materials?
    8 Posts 3 Posters 509 Views 3 Watching
      AcesHigh
      Is there a plugin or a way using the default drape tool, to drape, and the new contours on the mesh, already appear with the materials of the contour you used???
      lets say I have a road I want to project over a complex mesh. In 2d, I am able to create the road contour, and in theory, its easy to make it asphalt. But what if I want to create the aslphalt lines, pedestrian crossings, etc? I can drape them over the mesh, but then I have to select like 500 different polygons to paint them into white lines? (if drape trnasfered material too, you could make the road lines and pedestrian crossing, select it all, paint white, and drape it over the mesh)
        I think this will do what you want... after draping http://forums.sketchucation.com/viewtopic.php?p=358047#p358047
          AcesHigh
          thats great TIG, I had done a search but it had been futile... thanks a lot!
            I know - it didn't exist till you asked for it... 🤓
                AcesHigh
                  My new 'Super Drape' - that drapes one group onto another, and repeats the materials and texture UVs - is almost ready to publish - watch the forums tonight... Just debugging it... 🤓
                    Here's ***SuperDrape*** that does what you want in one step... http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
