    Keep material names in collada export
    9 Posts 4 Posters 12.3k Views 4 Watching
    • GaieusG
      I would like to have an option in the collada (dae/kmz) export to keep/maintain the SU material names. Something like the attached below.
      https://lh5.googleusercontent.com/-lsKKQQ7MsoU/ToRnoqcG1sI/AAAAAAAAGmk/O3jfOn-5cyM/ColladaExport.png
      The reason is: compatibility with third party products. Currently SU, when exporting to collada, renames each material to Material1, Material2 etc. I know the original reason/intention was good: to improve export to GE where non-English characters screwed up materials.
      However this way collada is almost entirely useless in third party applications. When I need to "tweak" a material there, it is often futile to find which material is which by the name.
      Even worse, some applications (would) allow "reloading" the model after some changes were done and when these changes include using new materials, the result is rather unpredictable as SU exports the modified model with the material names often "swapped" when renaming (thus previously grass material now ending up on the roof and roof tiles on the walls etc.)
      An easy solution could be to allow the user to keep the original SU material names (on his/her responsibility if you want, maybe with a warning popup). In this case, Google’s aim at making collada a universal 3D exchange format could even come true - without this, everyone will (and does) discard his possibility.
      • A
        Aerilius
        Not yet to speak of the thousand-texture-pieces for distorted texture coordinates (They make models unusable for rendering).
        As much as I appreciate SketchUp's support for the open Collada standard, but fixing these severe issues would turn SketchUp's sterling cutlery into gold.
        Why not make the generic filenames optional (and turn this option on for kmz export)?
        Why not just replace foreign characters while keeping the filename still readable?
        example: "my ŠketchUp.jpg"
        filename.gsub(/[^0-9a-zA-Z\-\_\.]+/,"_")
        becomes "my_ketchUp.jpg"
        instead of "texture1.jpg"
        • TIGT
          This is approach is already used in OBJ-exporters - like the v8 one AND mine - to ensure that the file-name AND materials'/textures' names are not going to mess up - still keep the names compliant AND unique but recognizable - otherwise we get
          ` "my ŠketchUp.jpg".gsub(/[^0-9a-zA-Z-_.]+/,"_")
          "my_ketchUp.jpg"AND "my ŞketchUp.jpg".gsub(/[^0-9a-zA-Z-_.]+/,"_")
          "my_ketchUp.jpg"which is NOT what we need... It straightforward to keep a list of materials/textures and if one already exists then the next one becomes say >>> "my_ketchUp1.jpg"`
          This is NOT hard to do, so why it's not been done for DAE yet is a mystery... 😕
          • GaieusG
            It's not only the current, "official" collada exporter but can happen with other exporters as well. Only recently Tomasz has overcome this behaviour for the Thea exporter for instance. You can also prevent it if you (pre) triangulate your mesh prior to exporting (collada will triangulate anyway so you will not add extra polygons)
            • GaieusG
              Aerilius: I see you are faster at fulfilling feature requests than the Googlers!
              http://forums.sketchucation.com/viewtopic.php?f=323&t=40397
              • A
                Aerilius
                Gaieus: I had a similar method in my KML tools. So it was only a little change and wrapping into a plugin. I hope this will not be accepted as a "fullfilled" feature request 😉
                Actually it is not a solution, because it exports all materials a second time and then afterwards manipulates the exported collada text file.
                Another point to think about:
                material's screen name or original texture filename? (SketchUp remembers each texture image's original file path)
                • GaieusG
                  I guess best would be the SU "screen name" as
                  • most users never meet the original image file name anyway* and this is also what you can modify easily in SU when it is needed. Now as for the technical details; you know how much I understand those... 😢
                  • I
                    Irteza
                    Dear, I am a beginner and using Sketchup. The issue is that I just installed the plugin and started exporting the .dae file, but still texture names are renamed as _auto_1....... and so on. I am using Sketchup 2017 and Windows. So do i need to edit .rb plugin file or there is something wrong.
                    • TIGT
                      @Irteza
                      What Plugin are you referring to ?***
                      DAE export is a standard built-in format ??
                      You can set up how the exported file is made using the Options in the File>Export[3d] dialog...
                      This is a very old thread...
                      Please [re]explain what you are doing step-by-step...
                      ***I see you double posted !
                      Again that's an old thread...
                      Try running it with the Ruby Console open and report errors...
                      I suggest you consolidate your posted into the plugin's thread...
