    Texture bugsplat
    5 Posts 3 Posters 802 Views 3 Watching
    • G
      gefhallen
      Hi, im currently dealing with texture bugsplat. whenever i tried to import a file as a texture it always ended up in Bugsplat which cause my SU8 to close down. i check at some other web to 'purge unused' but its no help. also tried to copy paste my objects onto a new document but it also didnt work. i can't see myself finishing my SU file withot being able to apply texture. i was wondering if anyone here can help ? thx.
      • TIGT
        I assume you mean an image-file to be used as a material?
        How big is this 'texture'?
        Can you post it here??
        Are you concerned about the texture or the model's SKP file itself???
        • G
          gefhallen
          yes, that's what i meant πŸ˜„ the file size 670 kb. i dont know if this might help, but i also have SU podium 2 installed.
          http://i92.photobucket.com/albums/l12/gefhallen/Palo_Escrito.jpg
          • TIGT
            Loads fine into my SKPs as a texture-material.
            Here's a SKM file of it - try puting that into a folder in Materials and bringing that in as a new material via the Material-Browser.
            It sounds like somethings up with your installation or the SKP - have you used Model Info > Purge Unused, AND > Fix Problems ??Palo_Escrito.skmPalo_Escrito.PNG
            • GaieusG
              Nice wood texture, by the way (thanks πŸ˜‰ )
              As TIG says, it loads just fine for me, too. Can it be a video card/driver issue (you never know)? Try to disable hardware acceleration under Window > Preferences > OpenGL to see (although the image is not particularly large)
