    Is there a way to select all with Default material?
    11 Posts 6 Posters 2.1k Views 6 Watching
    • brodieB
      brodie
      It's easy enough to select a material and pick "Select all with same material" but, of course, for whatever reason, this function doesn't work with SU's Default material. Is there a plugin that's rectified this?
      -Brodie
      • sdmitchS
        sdmitch
        Brodie,
        Remember faces have a front and a back. One can have material applied and the other not. So open the Ruby Console and paste this into the input box
        Sketchup.active_model.entities.each{|e| Sketchup.active_model.selection.add e if e.is_a?(Sketchup;;Face) && e.material==nil && e.back_material==nil}
        This will select all faces that have default material on front and back.
        http://sdmitch.blogspot.com/
        • brodieB
          brodie
          When i do that nothing happens and it replies with this in the ruby console
          Error: #<NameError: undefined local variable or method `ent' for main:Object>
          (eval):2537
          Am I doing something wrong?
          -Brodie
          • TIGT
            Here's a slightly modified version
            m=Sketchup.active_model;(s=m.selection).clear;m.active_entities.each{|e|s.add(e)if e.is_a?(Sketchup;;Face)&&!e.material&&!e.back_material}
            Copy the whole of the code into the Ruby Console and press <enter>.
            • brodieB
              brodie
              That's the ticket. Can you give me a quick rundown on how I'd give that a shortcut key? I'm guessing it needs to be turned into a .rb but I'll bet there's a bit more code that needs to go into it than just that bit. Any tips?
              -Brodie
              • thomthomT
                Selection Toys let you do that.
                • TIGT
                  -Brodie
                  Copy/paste this code into a file called ' TIG-selectByDefaultMaterial.rb' in the ../Plugins/ folder
                  module TIG
                    def self.selectByDefaultMaterial()
                    UI.menu("Plugins").add_item("Select By Default Material"){self.selectByDefaultMaterial()}unless file_loaded?(File.basename(__FILE__))
                    file_loaded(File.basename(__FILE__))
                  Then the 'Select By Default Material' item in the Plugins menu can be assigned a shortcut after a restart... ๐Ÿ’š
                  • brodieB
                    brodie
                    Thanks, that did the trick
                    -Brodie
                    • deaneauD
                      deaneau
                      -Brodie
                      module TIG
                      >   end
                      > end
                      TIG is in Hollyday could an other developer tell me, why i canยดt seen this in the plugin menue?
                      thank you
                      MADE, BORN AND LIVING IN BERLIN
                      Big Thank You to all Programmers
                      Some German words are so long that they have a perspective. M.Twain
                      • BoxB
                        I followed the instructions and it works for me.
                        • deaneauD
                          deaneau
                          yippy i have fund
                          thanks
