    How would you model this (well)?
    33 Posts 8 Posters 3.7k Views 8 Watching
      Both Punk'd by a tap 😉
      @Brodie
      If you can share the model (just the parts in question) when you're finished I'd like to upsample it with TGI3D to see the effect.
      • brodieB Offline
        brodie
        no problem
        • CarrozzaC Offline
          Carrozza
          @solo said:
          Pretty simple using TOS, EEby Vector and follow me.
          I understand the first two, but for what purpose did you use Follow Me?
          Boo, thanks for the video tutorial.
          • brodieB Offline
            brodie
            Here's the result. I think this looks pretty darn good. I combined a few of Boo's and Rich's suggestions.
            Basically I followed Boo's youtube video which worked great. I diverted a bit in that instead of scaling the inner circles I simply pushed them back into the faucet with the move tool which seemed to give a bit more uniform mesh and more what I was going for. I also took Boo's suggestion on smoothing but added a few more triangles which matches up pretty closely to what Rich was getting from Moi, as well as a bit of extra finesse on the ends. This seems to fix the smoothing issues.
            I've kept the inner bevel/circle as a separate component. Integrating it and smoothing it caused some more smoothing issues which didn't seem worth resolving as I like the output as it is.
            Here's a quick render and the final model. Let me know if you guys come up with any more suggestions.
            -Brodie
            Faucet 1.skp
            • boofredlayB Offline
              boofredlay
              Looks great.
                TGI made a smoother mesh on the radius but the edges didn't align.
                Nice result Brodie.
                Here's a MOI export...
                Brodie_Faucet_Blend.skp
                • X Offline
                  xrok1
                  “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  • X Offline
                    xrok1
                    • CarrozzaC Offline
                      Carrozza
                      Please Solo, Xrock, explain your techniques to a newbie modeler!
                      I must be missing something because after a couple of hours couldn't get as far as your models.
                      This is the last try with Fredo's round corners; notice bad shading, reversed faces, deleted faces... all kind of problems here!
                      Rich, even if MoI mesh is very clean still I see it's not without shading issues.
                      • brodieB Offline
                        brodie
                        I thought I'd include this. I got some good advice on how to do this in SU. It would be easy enough to translate this to SU as well. The advantage to this method is that it smooths out very well in Turbosmooth since it's all quads. I suspect artisan would see similar results.
                        -Brodie
                        • X Offline
                          xrok1
                          looks like you're right on track. my results with round corner weren't perfect either but its easy to erase and redraw a few edges. you can even move them around a little with the move tool to line them up better. try 3 or 4 with slight rotations of the cylinders then start with the cleanest one and tweak it a bit 😄
                          left one should work out cleaner than right one ...
                          experiment a little
                          • CarrozzaC Offline
                            Carrozza
                            Aaah, now I understand; I supposed your model was the result of one step operation. Thanks!
                            Still I'd be interested to learn Solo's technique to get the other type of bevel which is more common than the one discussed in this thread.
                            Cheers!
                            • X Offline
                              xrok1
                              as it turns out the one on the right did work out much better in this instance and after flipping just a few faces it seemed almost perfect.
                              the one on the left however had some major issues! go figure.
                              • 2 / 2
