    How well does Vray animation work
    renderpluginsextensions
    5 Posts 3 Posters 764 Views 3 Watching
    • brodieB
      brodie
      Does Vray animation work well within SU? How does it work?
      -Brodie
      • V
        valerostudio
        It works but I think most people stay away from it. SU itself is not great with animation workflow. There are a few tutorials on how to setup your lighting options for animation over at the Chaos forums and on the web.
        • andybotA
          andybot
          I've been able to get reasonable animations out of it using the flightpath plugin. Render times are not too swell, so that's been my biggest limitation. I haven't done one recently, but you can see on I did here:
          http://orbandesign.andyorban.com/movies/movie-2.htm
          Andy
          • V
            valerostudio
            My understanding is that if you plan on getting into a lot of animation work, you need Max and Vray.
            • andybotA
              andybot
              right. and learn Max... 🤢
              There's also Modo, Cinema4D, Maya, etc.
              Definitely depends on how much animation you're doing whether it's worth putting up with vfsu.
              Also, note that vfsu is limited with animating objects between scenes (as in you can't)
              In terms of setting up an animation, you can pre-calculate the light cache and the irradiance map. Here's the link to the tutorial I used. http://vray.us/vray_tutorials/vray_tutorial_irradiance_map2.shtml
              Andy
