    Native SU UV-mapping (maybe suitable for DUH thread?)
    3 Posts 2 Posters 294 Views 2 Watching
    • dereiD Offline
      derei
      I am often frustrated by lack of UV-mapping in SU. One interesting situation is when you import a image and "use it as texture", then all faces will respect the uv-mapping of the first one.
      But what if you don't import that image? how to fold it on a curved surface, without Projecting it (because of distortion implied).
      Well, I just figured it how and it very simple. Just follow the steps below:
      Enjoy πŸ˜‰
      step 1: just paint the object with needed material
      step2: Select Texture -> Position for one face, at your choice.
      ![JUST PRESS ENTER !
      Then use EyeDropper Tool to sample material from "positioned" face, and paint all other faces.](/uploads/imported_attachments/WcUV_03.png "JUST PRESS ENTER !
      Then use EyeDropper Tool to sample material from "positioned" face, and paint all other faces.")
      Final result (1)
      Final result (2)
      DESIGNER AND ARTIST DEREI.UK
      • broomstickB Offline
        broomstick
        I usually get the same result activating the Bucket (B) and then alt-click on the correct texture. That way when you click with the bucket on other faces, it will apply the material with the collected UVs
        πŸ˜„
        • dereiD Offline
          derei
          πŸ˜„
          Indeed, but the problem is how to set the "correct texture" because if you sample material from a face where was not "mapped" in some way, it will just sample the material. "Positioning" the texture does exactly that: assign UV on that textured face, so when sampling, you get the UV's too.
