    Exporting Guide Point data to csv file
    3 Posts 2 Posters 687 Views 2 Watching
    • jemagnussenJ Offline
      jemagnussen
      Hello,
      After searching through the net and this forum I fail to find any topic on exporting the x,y,z data of the guide points from a Sketchup drawing. There are many topics on importing and using guide points and point clouds, but have not found anything on the other way round.
      If I have a file with a lot of guide points made by placing guide points after single point survey and now wants to get all the data on all the points out into a csv file, how would I do that easily?
      I know I can use the "Tools" - "Utility" - "Query Tool" and place the cursor over the points and then get the data, but when you have several hundred points in a drawing then it get rather boring and time-consuming to extract all data with this approach.
      Best regards
      Jesper
      HP ZBook 15, Windows 10 64 bit
      Intel Core i7-6820HQ @ 2.70GHz
      32 GB Ram
      NVIDIA Quadro M2000M
        Here you go http://forums.sketchucation.com/viewtopic.php?p=354365#p354365
        It was quickly made from my earlier 'vertices' exporter...
          jemagnussen
          THANK'S TIG....
          You are truly amazing with the Ruby scripts. This saved me a bunch of time doing tedious work of creating long lists of data.
          Best regards
          Jesper
          32 GB Ram
