    How to "make group" for lines?
    10 Posts 5 Posters 440 Views 5 Watching
      Dnt
      Is there any way to "make group" a line?(just 1 straight line)
      1.there is a way by fredos on surface tool and 2nd dividing and making group(I dont know why doesnt it work some times πŸ˜• ) , right?
      any other way?
      I never had the nerve to make the final cut...
      • Chris FullmerC Offline
        Use the shortcut key - "g" to make component and "ctrl-g" for a group. That is how I get around that,
        Chris
        All my Plugins I've written
          Sketchup will make a group of a single object like a line, if the appropriate command is run from the menu - Edit > Make Group - rather than the similar context-menu item [which requires two or more entities to make a group].
          A shortcut is invaluable - so I recommend that you make a shortcut to the more flexible menu item, rather than the limited context-menu item - and double-check that you have made the shortcut to the correct item !
            Dnt
            Dear Chris , thank you. big help πŸ‘
            Dear TIG , Ill keep that in mind .thank you. πŸ‘
            • BepB Offline
              Bep
              A other (more laboruse) workaround is:
              Make a group of 2 lines ,than dubble click it to edit the group .
              Cut the line you dont won't in te group , exit the edit mode and paste in place the cut line
              Bep
              "History is written by the winners"
                Dnt
                Bep
                Dear Bep.
                I actually didnt get it . if you could explain more maybe with some images i would appreciate it
                A.A
                  Why not use my solution??
                    Dnt
                    Dear TIG
                    I just want to know the other ways...
                    best wishes
                      It's not only a single line entity but a single image entity (for example) too of which you cannot make a group from the context menu. What Bep means that you can always add some temporary geometry (easiest is to add a single line), select both, make a group and then just delete that excess geometry).
                      Sometimes simply making some simple entity like a line into a group is not enough for victory. You cannot scale an (on-axis) single line either but you cannot even scale it if you make a group either (unless you add some other geometry).
                      Now of course you may ask why I want to scale a line - the answer is simple: why not?
                        Dnt
                        Thanks Dear Gaieus and Bep.
                        I always appreciate your help.
                        sincerely A.A
