    [Plugin] Follow Me Helix (Updated 06-Jan-2012)
    45 Posts 17 Posters 37.3k Views 17 Watching
    • sdmitchS Offline
      sdmitch
      Now accepts decimal values for angular increment.
      In addition to now accepting a negative angular increment for those who like to go both ways, the plugin has had extensive re-write to help minimize the "kinks".
      Pre-select the centerline then run plugin. You are prompted for the radius of the helix, and the linear and angular increments. The helix is a single curve. The smaller the linear and angular increments the more points are defined.
      Improved the transition between segments around curves. Input values are retained between successive runs.
      Added code to check angles between segments and offers to do a spline fit if needed.
      Follow Me Helix
      http://sdmitch.blogspot.com/
      • soloS Offline
        solo
        Thank you once again for this requested plugin, it does exactly what I needed.
        http://www.solos-art.com
          Jörg
          fantastic!!!
          thank you very much!
          Jörg
            Interesting plugin. Thank you.
            How would you get more than 5 segments in a turn of the helix? Actually that's what I got with the example below but if I run it on a straight line I get 12 segments
            • sdmitchS Offline
              sdmitch
              The number of segments per turn is controlled by the angle increment. To only get 5 you would have to have a 72 degree increment.
              It could be the linear increment also. In trying to duplicate your results, if I made it long enough, I got something like yours.
                Got it.
                • majidM Offline
                  majid
                  verry handy and time saving plugin 😄
                  Thanks dear mate 👍 .
                  • JClementsJ Offline
                    JClements
                    Nice.
                    Would it be useful to have optional method to Linear Increment in which the user inputs the number of equal linear increments?
                      JClements
                      ❓ Anyone aware of a script that could be used with Follow Me Helix which automatically stitch the vertices of two selected spirals and triangulate to create a "spiral road"?
                      So, for example, select a path, run Follow Me Helix twice. The only parameter that would be different is the radius.
                        JClements
                        • sdmitchS Offline
                          sdmitch
                          JC, I'm sure TIG's EEbyRail would do the job but I'm assuming you don't have that so here is a little something I threw together that will work under the scenario you mentioned where on the radius is changed between runs of Follow Me Helix. In my example I used 30' and 50' for the radii and 1' and 10 degrees for the linear and angular increments.
                          Spiral Road
                          Add a surface between two helixes created by Follow Me Helix
                          • mitcorbM Offline
                            mitcorb
                            Hi, sdmitch:
                            Somehow I missed that you had updated and posted with a [Plugin] heading. Perhaps that version in the [req] thread by solo is older? Anyway, as I mentioned over there, I will download and experiment with the version in the post above. Thank you, once again.
                            mitcorb
                            • K Offline
                              K-TEE
                              It is very good. Thanks.
                                jdadesignstudio
                                Not sure if im missing something obvious, but mine are coming out very choppy...:
                                • sdmitchS Offline
                                  sdmitch
                                  It is usually a function of the linear increment entered and the length of the segments in the path. The increment entered is to long in comparison with the segments of the path in your case.
                                    jdadesignstudio
                                    Hmm...still having issues. Take a look at the images below-the line and arc both had the same parameters plugged into the helix plugin. I also tried changing the number of segments in the arc (to change the length of the segments) anywhere from 2 segments up to 92 segments. It seems where 2 line segments intersect, it creates a crooked piece...Let me know what you think.
                                    Thanks,
                                    Jon
                                    • sdmitchS Offline
                                      sdmitch
                                      Thanks,
                                      Jon
                                      Yes that happens because the linear increment starts on one segment and ends on the next one.
                                      Again, the linear increment you are using is to long for the curve you are trying to follow. Sometimes the curve and what you want just doesn't work.
                                      • sdmitchS Offline
                                        sdmitch
                                        Jon, After further testing, it looks like my last "improvement" wasn't an improvement at all so I have re-posted the privious version. I haven't been able to eliminate the "kinks" yet but it is still something that I am thinking about and have a few more ideas to try.
                                          jdadesignstudio
                                          Sounds good, thanks Sam! Its a really cool plugin, in the past I have used the draw curves plugin for helixes, but this plugin gives you some more control over the helix, in addition to the follow me feature.
                                            mattarth
                                            This is great for making a helix, thank you.
                                            Does anyone know of a way to make a helix with a radius that is a function of the distance along the original curve? I would like to draw a barrel spring (http://www.google.co.uk/search?q=barrel+spring&hl=en) but I don't know how to make it in sketchup. The radius would be something like r=x*(1-x)+1 where x is distance along the curve. Alternatively I could calculate a list of coordinates myself and input them; is there a way to do that in sketchup?
                                            Thanks in advance,
                                            Matt
                                            • 1 / 3
