    Round corner vs. follow me tool
    9 Posts 4 Posters 561 Views 4 Watching
    • jarynzlesaJ Offline
      jarynzlesa
      hi,
      how would get the same reasult after using round corner tool?
      what is your suggest?
      I think that this is obviouse from picture. desired reasult is the right box on the picture.
      http://www.vizualizaceschodiste.mypage.cz/
        jarynzlesa
        round corner join faces together, then texturing is a little bit awkward. how to avoid it?
        • mitcorbM Offline
          mitcorb
          If you wish the edges to show, use Ctrl+Shift+Eraser. Is this what you mean? I most probably interpreted your issue way too simply, and I apologize.
            jarynzlesa
            thx, this can be used at simply models.
            but what to do with complicated and large models?
              Sorry, I don't understand the problem or what your question is.
                jarynzlesa
                for some reasons I need to use round corner plugin - but it generates one face - you can see on attached picture. for texturing I need to separate needed faces.
                Untitled.skp
                  Tutn on hidden geometry (View menu), select the top face and its bounding edges (double click) and pull the soften slider to the left until they become hard edges. Now you can texture separately.
                  OR do not even unsoften but texture with hidden geometry on.
                    More like this?
                    See the settings at the arrow.
                    Edit: Csaba beat me to it and you can certainly do it as he indicates but my method keeps the borders of the rounding visible.
                      jarynzlesa
                      great idea working with hidden geometry - super - thank you Gaieus 👍
                      thank you Dave R you perfectly solved my problem 👍 .
