    Camera import and control
    23 Posts 6 Posters 6.9k Views 6 Watching
      mbarker
      @tig said:
      I'd expect the old RB file still to work OK in v2015.
      However, how are you making the camera-data file ?
      Try Notepad++ and set the file's encoding to UTF8-without-BOM...
      Report back...
      Dear TIG
      Worked a little more with the script and camera file and I am back in business!!
      Thanks!! 😄
        mbarker
        Hi TIG
        I found the old dialog regarding the file TIGimportcamera.rb
        I have updated the last Sketup update, but I can't get the script to work this time.
        Can you help me?
        Also, I would love to donate for having successfully used the script for many years! 🙂
        How can I donate?
        Kind regards,
        Mikkel
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @mbarker
          @mbarker
          I've replied to you in a PM
          I just tried it on v2024 and it works fine... although most of it is over a decade old !
          It imports a text file with a camera-view on each line.
          The camera-view entry must be as follows...
          name,xeye,yeye,zeye,xtarget,ytarget,ztarget,rollangle,fovangle
          there can be an optional value added after 'fovangle':
          ,image
          But you probably aren't wanting to use that.
          The values in the entry must be separated with the constants that are set in the RB file:
          Edit the ICVSEP and ICDSEP constants to suit your typical file's locale value-separator [' ',;:\t] and decimal.separator [. or ,]...
          In the example I show it's as a comma , separator and a .
          You might use a space or ; and a , to suit locale.
          Please check you are setting up you file correctly.
          As I said it works fine given the correct input.
          To attach an RB file just drop it into the message
          TIGimportcamera.rb
          There are donation buttons against many authors entries in the PluginStore and ExtensionStore³
          • 2 / 2
