    Camera import and control
    23 Posts 6 Posters 6.9k Views 6 Watching
      mbark
      Hi TIG
      Sorry I havn't given a quick answer...
      The script works!!!
      Would it be hard work to thange the units from inches to meters?
      Also, would it be possible to make a input panal inside sketchup where the camera values could be entered and manipulated.
      I appreciate your help very much, and i didn't think it was possible to get the same precision in sketchup as in 3ds Max - awsome!!
        @mbark said:
        Hi TIG
        Sorry I haven't given a quick answer...
        The script works!!!
        Would it be hard work to change the units from inches to meters?
        Also, would it be possible to make a input panel inside Sketchup where the camera values could be entered and manipulated.
        I appreciate your help very much, and i didn't think it was possible to get the same precision in Sketchup as in 3ds Max - awesome!!
        This is a version that assumes the units are in 'meters'...
        Copyright 2011 (c) TIG
        All Rights Reserved.
        THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
        WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
        MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
        Usage:
        Menu "View" > "ImportCamera..."
        Choose the file containing the camera data, in the following format:
        name,xeye,yeye,zeye,xtarget,ytarget,ztarget,rollangle,fovangle
        You can have one camera per line.
        The xyz values should be in 'METERS'.
        The two angles should be in degrees.
        If the ",rollangle," is replaced with ",upx,upy,upz," a vector can be used.
        New scene-tabs are made, each called 'name', with cameras as specified.
        Edit the ICVSEP and ICDSEP constants below to suit your typical file's
        value-separator [' ',;:\t] and decimal.separator [. or ,]...
        Donations:
        info @ revitrev.org via PayPal.com
        Version:
        1.0 20110908 First issue.
        1.1 20110910 METER version.
        TIGimportcamera.rb
          You can get a dialog that takes some input for camera data [but 'up' is a vector!] using this code [PC only, I'm afraid!]
          <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /></span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera Info..."</span><span class="syntaxkeyword">){</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">10624</span><span class="syntaxkeyword">)}</span><span class="syntaxdefault">unless&nbsp;file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxdefault"></span>
          copy+paste this code into a file called camera_info.rb in the Plugins folder and you get the new item in the menu after a restart...
            mbark
            Thanks TIG
            I have been looking for a way to get my exact camera information from max to sketchup for ..... a long time.
            Thank you for your time and work.
            • E Offline
              eco
              I was looking something like this but I have different camera coordinates information: xeye,yeye,zeye, xrotation,yrotation,zrotation, focallenght(mm), framesize(px)
                lapx
                pageexim is not working for me. Has anyone else had a problem getting it to work in su8? It makes the .sup file on export but when I try importing the .sup file it's doing nothing. It doesnt even give and error.
                Thanks,
                Lapx
                  mbarker
                  <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /></span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Camera Info..."</span><span class="syntaxkeyword">){</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">10624</span><span class="syntaxkeyword">)}</span><span class="syntaxdefault">unless file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxdefault"></span>
                  Dear TIG
                  It has been a long time since last and i would like to ask you a big favor regarding the camera import script. I used to have the user name mbark and you made the TIGimportcamera.rb. I am now using Sketchup 2015 and the script will not import. Can you help with an updated version. I would really appreciate it!
                    I'd expect the old RB file still to work OK in v2015.
                    However, how are you making the camera-data file ?
                    Try Notepad++ and set the file's encoding to UTF8-without-BOM...
                    Report back...
                      mbarker
                      Report back...
                      Dear TIG
                      Worked a little more with the script and camera file and I am back in business!!
                      Thanks!! 😄
                        mbarker
                        Hi TIG
                        I found the old dialog regarding the file TIGimportcamera.rb
                        I have updated the last Sketup update, but I can't get the script to work this time.
                        Can you help me?
                        Also, I would love to donate for having successfully used the script for many years! 🙂
                        How can I donate?
                        Kind regards,
                        Mikkel
                        TIGT 1 Reply Last reply Reply Quote 0
                          TIG Moderator @mbarker
                          @mbarker
                          I've replied to you in a PM
                          I just tried it on v2024 and it works fine... although most of it is over a decade old !
                          It imports a text file with a camera-view on each line.
                          The camera-view entry must be as follows...
                          there can be an optional value added after 'fovangle':
                          ,image
                          But you probably aren't wanting to use that.
                          The values in the entry must be separated with the constants that are set in the RB file:
                          Edit the ICVSEP and ICDSEP constants to suit your typical file's locale value-separator [' ',;:\t] and decimal.separator [. or ,]...
                          In the example I show it's as a comma , separator and a .
                          You might use a space or ; and a , to suit locale.
                          Please check you are setting up you file correctly.
                          As I said it works fine given the correct input.
                          To attach an RB file just drop it into the message
                          TIGimportcamera.rb
                          There are donation buttons against many authors entries in the PluginStore and ExtensionStore³
                          • 2 / 2
