    Cobwebs in selection window
    8 Posts 4 Posters 740 Views 4 Watching
      dav21
      i'm using sketchup 8 and i've updated my graphics driver. i'm noticing white lines when i make a selection window.
        That's probably a graphics driver issue. Try updating your graphics driver and see if that helps. You might also play with the OpenGL settings under SketchUp>Window>Preferences and see if you notice any difference.
        • AnssiA Offline
          Anssi
          What graphics card? This used to be a common problem with Intel motherboard graphics that don't support OpenGL well.
          Anssi
            dav21
            Anssi
            well i don't have graphics card separately installed. i have intel integrated hardware graphic 8.15.10.2246 support
              That would probably account for it.
                dav21
                well a friend of mine is running a 10 year old pc with windows xp and pentium 4 with no graphics card as well πŸ˜† and he doesn't have this problem. πŸ˜•
                  If he isn't having that problem, his graphics driver clearly supports OpenGL.
                  Read the System Requirements on the SketchUp website and compare them to your system.
                  • P Offline
                    penumbradesign
                    I had the same problem and I solved by turning the aero off on windows 7. For some reason, weird things happen when you turn on all the windows UI fluffy stuff.
