    Round edge question
    3 Posts 2 Posters 194 Views 2 Watching
    • V Offline
      vlad2005
      How can round edge in this figure?
      I try'it to upload to warehouse, but I can not pass goole conditions. I think it's a bug in Sketchup.
      Anyway, i put an capture to be more clear about what i want.
        Try Fredo's 'RoundEdges' plugin - see the 'Plugins Index' - and get all of the required files and install/activate it etc as instructed on the download page...
        This tool will let you round-off any such edges - provided that they are not too small [but if they are too small, then scale the affected geometry up, then round it, then scale back down - Sketchup/OpenGL has problems making very small [or very large] facets, but after they have been made they can be scaled down [or up!] to any size desired...]
        On the question of uploading the 3dWarehouse...
        You can attach SKP files to your posts here [up to 4Mb].
        In fact, you can attach most file formats to your posts - and the ones you can't attach directly can be 'zipped' and then attached as a .zip file!
        Later, if you want to upload a 'finished' SKP to the 3dWarehouse then make sure it's been 'purged' etc and that it meets the size limits imposed there too...
        • V Offline
          vlad2005
          Thanks!
          Seem to work. Yes, need to be scaled up but it's ok.
          Thanks again!
