    Script to convert Sketchup into Autocad?
    extensions
    14 Posts 7 Posters 3.2k Views 7 Watching
      svasilion
      Does anyone know of a plug-in or Rubyscript to helps cleanup all the little line segments that converting SketchUp models back into Autocad produces?
      • mitcorbM Offline
        mitcorb
        Is that only to do with curves, circles and arcs? Because Sketchup constructs these with segments, and Autocad sees them that way- not as smooth curves.
          svasilion
          I understand that sketchup converts all curved to straight lines. I'm thinking more in terms of how every straight line segment is divided into individual pieces at each intersection with another line. For example: a window that has muntins (say 2 wide x 3 high). The conversion turns the vertical muntin into 3 pieces, and each horizontal into 2 pieces. Plus, the window surround is then also divided into individual segments. It's very time-consuming trying to join these pieces back together. And if I choose to leave all the pieces separated, it makes for a messy acad drawing.
          • TIGT Online
            If you export a SKP as a 3D DWG then the Circle/Arc etc are retained.
            It's only with the limited 2D export that everything gets 'line-ized'...
            A SKP always has 'split' edges at intersections within the same context.
            Exactly what do you seek to do ?
              Jim
              The OP doesn't mention Circles or Arcs - it's about how SketchUp breaks edges automatically. There isn't any way we could modify the Pro exporter to "heal" edges for exporting. Perhaps one of the free exporters could be modified to analyse edges and then export broken, but otherwise co-linear, edges as a single acad line.
              • BepB Offline
                Bep
                I use Thom Thom's cleanup plugin before export ,and after a import http://forums.sketchucation.com/viewtopic.php?f=323&t=22920
                Bep
                "History is written by the winners"
                  svasilion
                  Thanks Bep. I'm looking forward to trying it out. Why do you also use it after you export to Autocad?
                  • TIGT Online
                    Please reread it, and think... Like many of us, he uses it before he exports his SKP model to a CAD format file; he also uses it after he imports a CAD format file into his SKP model... 😒
                    • arail1A Offline
                      arail1
                      No, but I sure would like such a script.
                      What the OP is talking about - imagine a 12 line grid in AutoCAD (12 lines vertical crossing 12 lines horizontal). In AutoCAD that's 24 lines. If you export it into Sketchup every line that crosses a line becomes a separate segment (12 X 12 + 12 X 12)= 288 lines.
                      Or imagine you draw a wall with doors and door casings in AutoCAD - the floor line is one line segment. But when you open the drawing in SketchUp the floor line becomes many, many separate lines for every point that a vertical meets a horizontal.
                      I go back and forth between SU and AC all the time and use the Join command but it's a bit of a pain. I've asked about a script that would automatically join all contiguous lines into one line segment on the AutoCAD forums and I was told that a macro could be easily done but I never followed up on it.
                      • TIGT Online
                        Perhaps use MPEDIT if you have the older AutoCAD free Express Tool installed.
                        In newer AutoCAD you can type PE for polyline edit then M to SELECT multiple lines, once you have selected all the lines press ENTER then you will get a set of options in the command-line, press J for the JOIN command.
                        There are several AutoCAD resources/tools like:
                        http://www.dailyautocad.com/2008/04/hip-tip-converting-lines-and-arcs-to_22.html
                        http://www.dailyautocad.com/2009/04/joining-broken-objects-with-join.html
                        http://www.cadtutor.net/tutorials/autocad/joining-lines-polylines-and-arcs/
                        http://www.black-cad.homepage.t-online.de/pediten.htm
                        http://www.jtbworld.com/lisp/pljoinfuzz.htm
                        http://www.cadtutor.net/forum/showthread.php?32216-LISP-to-join-many-lines-to-a-single-3D-Pline
                        • mitcorbM Offline
                          mitcorb
                          @TIG:
                          Thanks for that list. The first ones, by Orhan Toker, appear to be a real wealth of knowledge on things beyond the issue at hand. Thank you, again.
                          • AnssiA Offline
                            Anssi
                            AutoCad has the Overkill command that can be used to process imports from SU. It automatically converts colinear line segments into single lines, and erases overlapping objects. It generally does an OK job.
                            Anssi
                            • mitcorbM Offline
                              mitcorb
                              Is that really what the command is called? I would have never associated the words "Autocad" and "Overkill" 💚
                              • AnssiA Offline
                                Anssi
                                Yes. "Overkill" it is. The command started as a part of the unsupported Express Tools (I am not quite sure whether it is still in those or if it was "promoted" into a "regular" command already). AutoCad is similar to SU in that some of its functionality comes from commands that are actually plugins.
                                Anssi
