πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
WebDialog.set_html fails under Safari 5.0.6
111 Posts 7 Posters 17.2k Views 7 Watching
    Found one of my older posts - I'd forgotten about. 😳
    http://forums.sketchucation.com/viewtopic.php?f=180&p=306204#p306122
    Similar, expect that I made it work with file:// - now that seems to have been closed down as well.
      driven
      @thomthom said:
      ENV['TMPDIR'] yields /var/folders/jw/jwKHMuVxGEi4OILNAxFfgU+++TI/-Tmp-/ :?
      I can't even find that on the disk...
      the path to the -Tmp-
      Macintosh HD/private/var/etc...
      private is a hidden folder
      the easiest way to expose hidden folders is HiddenFiles widget softpedia has it
      I've got both versions of Safari if you want me to test things..
      @fredo, I'll pm you after I test on 5.0.6
        driven
        I think a load or reload button may be required or a least help debug, sort of got Fredo's working now.
            driven
            sorry, it was late and I didn't explain anything...
            Fredo made some tweeks and I was doing the mac testing.
            when either fredo's LibFredo6 settings dialog or Cleanup3 dialog are first opened they show in WebInpector Resources as (about:blank)
            initial load of either
            (about:blank) pages can't be reloaded using normal right-click reload, however with fredo's if you make a selection that forces a content reload like changing the parramaters, (about:blank) is replaced by the proper page, the errors disappear and everything works.
            after changing checkbox selection
            with Cleanup3 there is nothing to click that will force a change, to see if it would then reload properly.
            sorry if my logic is flawed, but hopefully this explains what I mean.
            john
              I split of the discussion for this particular issue as it's a problem with the WebDialog class itself and not the plugin in itself.
                Dan Rathbun
                Didn't John do some testing awhile back where he had to use " file://localhost/" or similar ?
                What if the resources were in the user's path.. " **~**/Library/Application Support/...etc."
                I'm not here much anymore.
                  Yes, but now even that fails. 😞
                    Dan Rathbun
                    @thomthom said:
                    Making a cleanup operation from Ruby won't be so easy I think...
                    Don't overlook the Standard Library... " tmpdir.rb" and " tempfile.rb"
                      Dan Rathbun
                      Been having similar problems trying to run a local copy of firebug... looks like it's time to set up a simple server. I think Dan Berger has one in the win32-api package.
                      • fredo6F Offline
                        fredo6
                        I agree, and before we engage in workarounds and other approximate fixing, we really need to understand where the issue comes from and why it does materialized differently in two versions of Safari which should not be so different (5.03 and 5.06, correct?).
                        In any case, we need to hear from the SU team, because they must have an idea of how the web dialogs are integrated with Safari on Mac and clarify why security is handled differently by a set_html and a set_file.
                        Fredo
                        • TIGT Online
                          Isn't it that there are three different BUT 'related' .set_ methods?
                          **WebDialog.set_file** Used to set a *local* HTML file to display in the webdialog. Arguments: filename = The filename for the webdialog file (HTML file). path = (optional) A path to which the filename is relative. Returns: nil Usage: dialog.set_file("C:\\Temp\\mypage.html")
                          OR
                          **WebDialog.set_html** Used to load a string of *HTML code* into the webdialog. Arguments: html_string = A string of valid html to display in your webdialog. Returns: nil Usage: dialog.set_html("Hello world!")
                          OR
                          **WebDialog.set_url** Used to load a specific *URL* into the webdialog, i.e. it loads a *web-site* into the webdialog. Arguments: url = The URL for a specific web site. Returns: nil Usage: dialog.set_url("http://www.google.com")
                          They are not meant to be interchangeable πŸ˜•
                            TIG: The problem is that when you use .set_html you do not get access to local resources any more under OSX Safari 5.0.6+.
                              Dan Rathbun
                              Ok.. now, both Safari and Chrome use Webkit.
                              IF (assumption) both implement security polices in a similar way (on Mac via a manifest plist file inside the bundle,) you might compare the settings pre and post Safari 5.0.6.
                              On Chrome the settings are in file "com.google.Chrome.manifest", so (hoping,) that for Safari, the file would be something like "com.apple.Safari.manifest".
                              I'm going by the Chrome policy list when I suggest looking for policy "DisabledSchemes", or "SafeBrowsingEnabled", "ImagesBlockedForUrls", "JavaScriptAllowedForUrls", etc. (see the list... or find the list explicitly for Safari.)
                              P.S. : I wonder if Mac Sketchup changes any of these Safari security policies when it installs, to enable correct use of WebDialogs, ... and by upgrading to a newer Safari version, the policy file is overwritten. (So a comparison of the Safari manifest file, both pre and post Sketchup install, may also be in order.)
                                driven
                                have you got an example of .set_html that works on older Safari, I've been going through all my old bits and I can't find an example that ever worked, heres some variations of .set_url and .set_file that all (bar one) work under Safari 5.0.6, I'm not including the files, unless you want them, it's more about the syntax, which is slightly different from 5.0.3 if you use .set_file("file:///...) Safari adds an additional file:/ to the url and reports an error
                                dlg1 = UI;;WebDialog.new("BoilerPlate1", true, "BP1", 200, 200, 110, 0, true);
                                dlg1.set_url("file;///Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/WD_BoilerPlate_cln/demo/tests.html")
                                dlg1.set_background_color("#fff")
                                dlg1.show_modal
                                #works
                                dlg2 = UI;;WebDialog.new("BoilerPlate2", true, "BP2", 200, 200, 310, 0, true);
                                dlg2.set_file("/Volumes/Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins/WD_BoilerPlate_cln/demo/elements.html")
                                dlg2.set_background_color("#fff")
                                dlg2.show_modal
                                #works, BUT an external ajax call for js fails, local backup js loads instead
                                dlg3 = UI;;WebDialog.new("BoilerPlate3", true, "BP3", 200, 200, 510, 0, true);
                                dlg3.set_file("/Library/Application Support/Google SketchUp 8/SketchUp/plugins/WD_BoilerPlate_cln/test/index.html")
                                dlg3.set_background_color("pink")
                                dlg3.show_modal
                                #works
                                dlg4 = UI;;WebDialog.new("BoilerPlate4", true, "BP4", 200, 200, 710, 0, true);
                                dlg4.set_url("file;///volumes/Macintosh%20HD/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/WD_BoilerPlate_cln/test/index.html")
                                dlg4.set_background_color("grey")
                                dlg4.show_modal
                                #works
                                dlg5 = UI;;WebDialog.new("BoilerPlate5", true, "BP5", 200, 200, 910, 0, true);
                                dlg5.set_url("file;//localhost/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/WD_BoilerPlate_cln/404.html")
                                dlg5.set_background_color("#fff")
                                dlg5.show_modal
                                #works
                                dlg6 = UI;;WebDialog.new("BoilerPlate6", true, "BP6", 200, 200, 1110, 0, true);
                                dlg6.set_file("/Library/Application Support/Google SketchUp 8/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
                                dlg6.set_background_color("#fff")
                                dlg6.show_modal
                                #works
                                dlg7 = UI;;WebDialog.new("BoilerPlate7", true, "BP7", 200, 200, 1310, 0, true);
                                dlg7.set_url("file;///volumes/Macintosh%20HD/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
                                dlg7.set_background_color("#fff")
                                dlg7.show_modal
                                #works
                                dlg8 = UI;;WebDialog.new("BoilerPlate8", true, "BP8", 200, 200, 1510, 0, true);
                                dlg8.set_url("file;//localhost/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
                                dlg8.set_background_color("#fff")
                                dlg8.show_modal
                                #works
                                dlg9 = UI;;WebDialog.new("BoilerPlate9", true, "BP9", 200, 200, 1710, 0, true);
                                dlg9.set_url("http://localhost/Library/Application%20Support/Google%20SketchUp%208/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf")
                                dlg9.set_background_color("#fff")
                                dlg9.show_modal
                                # DOSEN'T work[it is a pdf afterall]... but do I get a Not Found message
                                #The requested URL /Library/Application Support/Google SketchUp 8/SketchUp/plugins/_LaptopLearnig/Ch1/TextBook.pdf was not found on this server.
                                dlg10 = UI;;WebDialog.new("aceSUedit", false,"ace", 900, 600, 50, 350, false);
                                dlg10.set_url("http://upstairs.lan/cloud9/cloud9/support/ace/ModalWindow.html")
                                dlg10.show_modal
                                #works and is an extremely complex html with lots of dynamic content
                                I'll set these all up on Safari 5.0.3 tomorrow and see how they fair.
                                john
                                  Dan Rathbun
                                  @driven said:
                                  ... if you use .set_file("file:///...) Safari adds an additional file:/ to the url and reports an error...
                                  I'm purty sure that it's the Sketchup API UI::WebDialog code that prepends all set_file() arguments with "file://", happens on Windows as well.
                                  I tried set_file("file://localhost/path/to/local/file.html")
                                  and got that Sketchup error dialog (I believe it had the Sketchup icon in the upper left of the caption bar,) saying:
                                  ' %(#8000BF)[Could not find file: "file://file://localhost/path/to/local/file.html"]'
                                  I would say that method should check to see if the substring is already there before prepending it.
                                    Dan Rathbun
                                    Here's a bug report at Webkit Bugzilla on local file:// handling broken.
                                    Webkit bug #10777
                                    It was reported in 2006 !
                                    The 'reporter' also filed a bug at apple: #4809075
                                    .. because he was unsure if it was Safari, or Webkit; but never got back to his original report and said what happened.
                                    So the status remains: UNCONFIRMED
                                    I tried to log into the apple bug reporter to check on #4809075, but got a login error.
                                    • TIGT Online
                                      ...if you use .set_file("file:///...) Safari adds an additional file:/ to the url and reports an error...
                                      BUT surely that's not really an 'error' ? It's just a logical application of some rules.
                                      The .set_file() method is expecting a file path - like 'C:/temp/myfile.txt'.
                                      The .set_url() method is expecting a url like 'http://www.forums.sketchucation.com' OR 'file:///C:/temp/myfile.txt' if it's a local file path.
                                      The .set_file() method takes its argument and it prepends a hard-coded initial 'file:///' to make it into suitable 'url' friendly code, from the bald file path: this is just like what happens when you try to open a local file with UI.openURL(), which requires that you have added the initial 'file:///' to any local file path etc.
                                      The .set_**html**() method is expecting a some 'html code as text' and this is a more serious issue, to this side one.
                                        webdialog.set_html( 'Hello World<hr><img src="file:///Users/thomas/Desktop/helloworld.jpg" alt="image should be here"><hr>Bye World' )
                                        Very crude example, invalid HTML, but it's the bare bones. The image would load in older Safari.
                                        Never been a problem before... Something must have changed at 5.0.6.
                                          .set_file and .set_url isn't really the problem here. They both work the same as pre-5.0.6 as far as I can tell.
                                          .set_html is the core of the problems.
                                          • 6
                                          • 2 / 6
                                          2 / 6
