    Ugly section face cuts
    13 Posts 6 Posters 1.1k Views 6 Watching
    • R
      rock1
      I'm modeling in sketchup, and as you all know its a native problem of sketchup to unnecessarily section faces and models. It occurs rarely but the model i'm making, it's really interrupting the modelling process. I updated my graphic card driver but the problem remained. I uninstalled my graphics driver but the problem is still there. What should I do?
      http://i.imgur.com/VkERU.jpg
      Signature removed by SCF Admin
      • Chris FullmerC
        Is this a very large file in dimensions? Does it cover a few square kilometers?
        If not, do you have some stray geometry, maybe hidden or on a layer that is turned off? Or is the model far away from the axis origin? All of those things will make the clipping severe on a model.
        All my Plugins I've written
        • R
          rock1
          my site is 11 acres, i have stray lines deleted with the plugin that's made 4 it, applied cleanup by thomthom. the problem persists.
          • GaieusG
            @rock1 said:
            my site is 11 acres
            That's the problem. See here:
            http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36261
            • R
              rock1
              @gaieus said:
              @rock1 said:
              my site is 11 acres
              i changed the perspective angles a lot of times, moreover deleted the cad file that my model had, the ugly cuts remain 😞
                Did you do any of the things that were recommended in the link Gai posted? It doesn't sound like it.
                • R
                  rock1
                  this model is really driving me nuts, when i enable shadows, the view gets divided in half, with the buildings showing up in the upper half, and the brown ground colour in the bottom half 😒
                  Mr. Dave R I did everything that's mentioned in that link. If it doesn't sound like it, then what can I do πŸ˜’
                    It sounds like you've drawn the model partially below the ground plane. That would account for the shadow problem.
                    I asked my other question because in the past you've been given solutions to your problems but ignored them and continued to complain that the problem isn't fixed.
                    • pbacotP
                      Rock
                      I think this is the bit you need (from the Help link):
                      This can also happen if your model is very far away from the origin point (the point where the red, green, and blue axes intersect). In that case, you can move your model closer to the origin point following these steps:
                      Select all of the geometry in your model by typing Control+A or Command+A, or by clicking and dragging the Select tool across your geometry.
                      Change to the Move tool by going to Tools > Move.
                      Grab a corner point of the selected geometry that is on the ground plane and start to move the selected geometry.
                      Type [0,0,0] (including the square brackets) in the Measurement toolbar (which is in the lower-right corner of the SketchUp window). This causes the selected point to be moved to the origin point.
                      Move your house to the origin (and you may have to move again if you are working a lot on another part of the 11 acres (nice size lot).
                      Peter
                      • R
                        rock1
                        @pbacot said:
                        Rock
                        Peter
                        I did this too but still getting that cuts man 😒 moved to the origin, changed perspective angles, deleted autocad stuff, still getting failed
                        • pbacotP
                          Sorry it's not working. And you ARE in perspective camera view?
                          • R
                            rock1
                            Yes I am in perspective. Sketchup is really troubling me sometimes in the components browser, on clicking the down arrow drop down menu in it when I click components, it gets stuck. i.e. for e.g. if I have the landscape library opened and i want to go back to the architecture pack it won't show up. When I restart sketchup, it starts working fine. Looks like my system has a sketchup virus or somethin'
                            • KrisidiousK
                              Krisidious
                              you have another post for this question... try to keep your posts together and not spread out.
                              this is a known issue called clipping. your model has extremely small geometry and extremely big geometry... and the origin is to far from the farthest point.
                              By: Kristoff Rand
